Any advise would be awesome! I have a "06 Envoy Denali and this morning on my message center it read 'stability track active". Granted, it was wet outside but nothing really bad. The truck out of first gear felt like a hard shift. Nothing happen on the rest of the gears, only out of first. After re-starting my truck, the message was gone, and my problem went away. Yes, it was still wet outside. Help! I'm thinking of taking this back to the dealer to run a diagnostic, but I also want to know if anyone has had any similiar problem????
I have a 08 Envoy Denali for three month now after a 04 TB however on evening as I was drive the same thing happened I notified GM pushed ON-Star to see why..suggested I take it to the dealer get to the dealer to be told they couldn't find anything wrong...it never happened again thank God I chalked it up as a computer glitz...:m2:
This bulletin provides information on two different conditions.
Condition #1
Some customers may comment on a Service StabiliTrak® indicator light along with a Service StabiliTrak® message displayed in the DIC. Upon investigation, the technician may find DTC C0196 set in history.
Condition #2
Some customers may comment on a blinking StabiliTrak® indicator light along with a StabiliTrak Active message displayed in the DIC during normal driving conditions. No DTCs will be found with this concern.
Cause
This condition may be caused by a software anomaly within the electronic brake control module (EBCM) that allowed the yaw offset to be falsely learned.
Correction
Do This
Don't Do This
Reprogram the EBCM.
Do not replace the yaw sensor or EBCM for this condition.
Important: From the controller list, select "VSES Vehicle Stability Enhancement System Control Module."
If routine diagnosis using SI does not reveal any obvious cause, reprogram the EBCM using SPS with the latest software available on TIS2WEB. Refer to the Service Programming System (SPS) procedures in SI. As always, make sure your Tech 2® is updated with the latest software version.
Warranty Information (excluding Saab U.S. Models)
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
H2508
Electronic Brake and/or Traction Control Module Reprogramming with SPS
Use Published Labor Operation Time
Warranty Information (Saab U.S. Models)
Labor Operation
Description
Failed Object
Fault/Reason Code
Location Code
Warranty Type
Repair/Action Code
Labor Time
1002003
52160
79
0
01
05
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
Condition #1
The problem with mine after it came on the only way to turn it off was to turn vehicle off and restart....Took it to dealer and they replaced the module faulty
Related Threads
1.3M posts
173.7K members
Since 2004
