Spare Tire Winch replacement - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Tires
Tires Tires
Old 05-18-2008, 08:02 PM
Trail_boy_333 Trail_boy_333 is offline
Light Pewter Metallic 4.2L I6 AWD
Any thoughts on where the best place is to get a replacement winch for a 2003 Trailblazer LT EXT?
I have read many of your posts about the spare tire winch. I had a terrible time getting my spare tire off, and ended up cutting off the end of the cable to free it. Now that I got the winch off of the car, I found that it is beyond repair as the cable got wrapped around the pulley and the plastic housing is broken into many pieces. I have looked around on some sponsor Web sites but haven't found a replacement yet. Any help would be appreciated.
Old 05-18-2008, 08:16 PM
petevw's Avatar
petevw petevw is offline
Red Jewel Tintcoat 4.2L I6 4X4
I found the winch on GMpartsdirect.com
List Price:$112.15 Their price:$68.82
It's listed under "rear body & floor" in the catalog.
Hope this helps
Always remember: wherever you go, there you are!
PCM4less,HID,DRL killer,cabin air filter,Mobil 1,K&N,LED's,230K+,
Old 05-27-2010, 05:21 PM
sierra305 sierra305 is offline
2003 GMC Envoy SLE
Red face spare tire winch
looking for spare tire winch for 2003 gmc envoy and need to ships in canada
like to know were to locate one if anyone know how and were to find one of those please reply to normand_305@yahoo.com
ps new or good used one too
Old 05-27-2010, 05:34 PM
gordinho80's Avatar
gordinho80 gordinho80 is offline
Silverstone Metallic 4.2L I6 4X4
Contact one of the off-roaders who no longer uses stock size spare. I've already donated mine to my brother in law... who's broke.
Mario -
OffRoadTB.com
Old 05-27-2010, 09:31 PM
the roadie's Avatar
the roadie the roadie is offline
Or buy from parts4chevys.com. I think they ship.
Old 07-29-2012, 01:01 PM
jakevader95 jakevader95 is offline
Imperial Blue Metallic 4.2L I6 4X4
2006 T/Blazer EXT spare tire
No good deed goes unpunished.
I decided to check the air in my spare this morning. After 2.5 hours the spare is in the garage and the spare tire carrier is in the garbage.
After reading the owner’s manual and cranking down the spare tire. It kept jamming every half inch or so. Finally by going up and back down again, I got it low enough to remove.
Yes, it was low, about 21 psi. So I pumped it up to 35. It was filthy and badly corroded from dirt roads and road salt. I power washed it to remove the poultice.
I greased the retrieval cable and tried to crank it back up, but nothing happened. The cable is almost on the ground and the spare won’t go up.
So I removed the entire spare carrier from the frame. Two of the three j-nuts holding it broke. Liquid Wrench and vise-grips got out all the pieces. The retrieval reel had jammed and literally broke apart (the housing is mostly plastic. The entire mechanism will have to be replaced (no doubt a $100 part at the dealer). The cable was buckled.
Currently contemplating driving with no spare. Just a couple of cans of fix-a-flat or a call for a tow truck.
Old 07-31-2012, 05:54 PM
spare tire winch
exact same problem as Trail Boy 333
If you drive in winter weather and salt, better plan to remove your spare and grease the cable frequently.
Rear spare tire carrier AlekG Off-Road 13 05-20-2017 02:48 PM
Anyone break their spare tire winch thing? itchyfishnv OEM Issues 37 06-06-2013 07:56 PM
Spare Tire Secondary Latch? and Tire Rotation Puzzler Coach Steve Tires 18 02-26-2009 03:07 PM
Spare Tire Winch Alternatives? sycoares OEM Issues 7 03-02-2008 06:29 PM
Spare Tire Question jaylind OEM Issues 36 01-30-2007 10:06 PM
