| The "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here. |
08-08-2012, 02:10 PM
2002 Chevy TrailBlazer LT EXT Summit White 4.2L I6 2WD
P1514 and pending P0300
Hi I'm new to this thread and I have a 02 trailblazer.recently i replaced the sparkplugs and now im getting a p1514 and a pending code p0300 i checked and cleand the throttle body and did not find any problems. I started my TB and it ran fine at idle but until i took it out engine light came on and reduce engine power and now it idles rough.any ideas on what to look for.
08-08-2012, 03:32 PM
dtc p1514 and pending p0300 cont.
Ijust checked for any vacum leaks and no leaks were found.I just had the trailblazer running for a while and took it out to drive but has no power feels like it wants to die.rpms fluctuates between 5 and 6.
08-08-2012, 09:31 PM
2002 Chevy TrailBlazer LTZ Red Jewel Tintcoat 4.2L I6 4X4
You removed the throttle body from the engine, cleaned BOTH sides, and had the battery disconnected for at least 35-40 minutes while doing the cleaning?
Always remember: wherever you go, there you are!
PCM4less,HID,DRL killer,cabin air filter,Mobil 1,K&N,LED's,193K+,
08-25-2012, 08:06 AM
2002 Chevy TrailBlazer LT Sand Beige Metallic 4.2L I6 4X4
did you check the spacing on the spark plugs. if the spacing is off it can cause that, it happened to me.
2002 Chevrolet Trailblazer LT: 8000K HIDs, K&N CAI, DRL delete, Viper 5901, Cherry Bomb Custom Exhaust, Pioneer HU
08-25-2012, 02:33 PM
Huh???
OP hasn't responded to any questions/suggestions, but it says "solved" on the thread title. Real nice when posters come here looking for help, get help, fix their problem, but offer no thanks for it.
12-11-2012, 07:46 PM
2005 Chevy TrailBlazer LT Black 4.2L I6 4X4
Po306
I was wondering if anyone has new information regarding PO306, my MIL is constantly on now. In the past it would show up occasionally, perhaps once every couple of months. These are the things that I did, swapped coils, put in the AC Delco Iridium 41-103 spark plugs, new air filter, removed the throttle body and cleaned it on both sides and pulled the two PCM fuses and waited 30 minutes. At that time which was a few months ago everything was fine. Other than the code the TB has a slightly rough idle, but has great power for a vehicle with 174,000 mi.
Jake1
| Sponsored Links |
