HELP - sudden explosion sound whild driving - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-29-2013, 02:08 PM
omaromar50 omaromar50 is online now
Brown 4.2L I6 4X4
Dears,
I am new member to your forum, I have recently bought 2002 Envoy SLT with 190 KM.
The car seems to be having many complicated problems, but what I am concentrating to solve right now is, sometimes when accelerating I hear a very loud explosion sound, with black exhaust. sometimes I feel that the car engine is vibrating hardly and the acceleration is badly affected after the explosion, even more some times the engine stops directly after the explosion, but when I start it again it runs, but with very bad acceleration.
Sorry for my bad English, Appreciate all your support
Old 01-29-2013, 05:24 PM
lhassebrock lhassebrock is offline
I would suggest you stop driving it and get all the codes read to see what's wrong with it. If ther's not already major damage, there will be soon if you keep driving it around.
Old 01-30-2013, 07:50 AM
BanditGTP BanditGTP is offline
2003 GMC Envoy SLT XL
Light Pewter Metallic 4.2L I6 AWD
It sounds like it might be a backfire. I had that on a work van several years ago. After a while (and many backfires) it blew up my muffler and needed to replace the exhaust. I'm not sure what the cause was since my boss had the van repaired.
Old 01-30-2013, 04:30 PM
Machoman Machoman is offline
2005 GMC Envoy SLT
yes it does sound like a backfire.
Old 01-30-2013, 10:04 PM
Brown 4.2L I6 4X4
Dears
Thanks for your replies
What can be the cause for the backfire??
Old 01-30-2013, 10:34 PM
GM Lover's Avatar
GM Lover GM Lover is offline
2005 Buick Rainier
CASHMERE METALIC 4.2L I6 2WD
Originally Posted by omaromar50 View Post
Dears
Backfire is caused by the accumulation of unburned gases that suddenly burst or explode. Check for a clogged catalytic converter. Good Luck
Old 01-31-2013, 01:34 PM
Brown 4.2L I6 4X4
what can be the cause for unburned gases?!?!
Old 01-31-2013, 03:30 PM
A missfire can cause the symptoms you're describing. Bad plug or coil. Are any of your lights flashing on your dash when this happens?
Old 01-31-2013, 06:22 PM
Brown 4.2L I6 4X4
Actually no any lights showing
Before or after, but some times the dashboard is showing low oil level while it is ok.
Old 02-02-2013, 05:09 AM
Brown 4.2L I6 4X4
I have to give a big thank to every one gave an advise in this topic, specially lhassebrock.
Actually, I have find one coil not working and I am going to change it tonight.
Is it normal for these coils to go bad, or there must be a reason that I have to search for before just changing the coil. any more advices?
is there a big difference between the Original and the after market ones?
BTW the installed is Delphi.
GM Lover,BanditGTP and Machoman I will go next to check the catalytic converter. what are the symptoms that it is clogged? as I hope the back fire will end after changing the coil, I hope so.
Appreciate all your help
