Need Help Code 1481 What Is It ? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain
02-09 Vortec 4.2L I-6 Engine and Drivetrain Q&A forum for engine and drivetrain repairs/modifications/tuning.
Old 11-16-2006, 08:51 PM
macbe macbe is offline
2002 Trail Blazer LTZ, 99,000 miles SES light came on, Auto Zone read the code. P1481 came up 2 times.
( Fan secondary low with high fan on ) Please let me know what that
means. Macbe
Quick reply to this message
Old 11-16-2006, 09:10 PM
Sparty's Avatar
Sparty Sparty is offline
Z71 . Onyx Black 4.2L I6 4X4
What was the letter that was before the number, go here http://www.iequus.com/support/obd2_definitions.php, if you type in 1481 in with different letters in front of the number you get different difinitions. If you use p1481 you get the "Fan secondary low with high fan on", if you use b1481 you get "Wiper Washer Fluid Level Sensor Circuit Short To Battery" and if you use c1481 you get "Right Front Wheel Brake Pressure Control Plausibility Failure".
Old 11-17-2006, 05:51 AM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
Sounds like your fan clutch is on it's way out. P1*** codes are typically manufacturer specific. Our POS electro/mechanical fan clutches are specific to this truck, so it's got it own code.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 06-25-2007, 11:03 PM
sk7500 sk7500 is offline
P1484 troubles
My wife has a 2002 Envoy 4.2L 77K miles. about 6 months ago the water pump went out, so I installed a new one. about a month ago we get the "Check Engine" light and "Reduced Power" Light. The fan was staying engauged all the time. I found a suposedly Genuine GM fan clutch and sensor on the internet and I put it on. Cleared the codes and you guessed it after abput a month the light came on again with the same P1484 code. Acording to my Chiltons repair manual that code means "Cooling Fan RPM Error" I don't have overheating problems and the clutch seems to be working OK. The fan does not rub the shroud anywhere that i can tell. I hate the thought of plunking down $370 at the dealer if there is something else I can check out. Any ideas? Thanks
Old 06-26-2007, 10:22 AM
vball61 vball61 is offline
The PCM will set P1481 if it detects a loss of the cooling fan speed signal for more than 11 seconds. It will then command the fan clutch to 100%, and will light the MIL if the signal fails during a second consecutive ignition cycle.
There are three circuits between the PCM and the fan which support the cooling fan speed signal:
DESC.; COLOR; Pin at FAN; PCM; C105
5v REF; GRY; E; WHT-60; A
Signal; DK BLU; D; BLU-43; B
GND REF; GRY or GRY/WHT; C; BLU-60; C
C105 is the 10-way I/P-to-Forward lamp harness inline connection, located near the underhood fuse block.
Old 06-30-2007, 06:31 PM
My code is 1484
Thanks for the info. I disconected the plug by the fan and checked the grey wires for 5V and continuity to ground. They checked oK. I also checked the wires for loose connections. everything checks out. I really don't know what to do next.
Build Sheet lucaswhunter General 29 05-27-2012 01:42 PM
my build sheet 20ohfivetb General 0 06-01-2008 12:09 PM
Code cleared itself. Now time for inspection. bugeyed OEM Issues 0 12-09-2007 08:22 PM
Reduced Engine Power due to a P0128 code? onip28 OEM Issues 2 12-09-2007 03:02 AM
Cat is getting plugged AGAIN!! Bonez2 02-09 Vortec 4.2L I-6 Engine and Drivetrain 10 06-29-2007 03:40 PM
