Loud lifter noise - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-22-2009, 12:28 PM
Speedracer13090's Avatar
Speedracer13090 Speedracer13090 is offline
Loud lifter noise
i have a 2002 TB with 117K .. Good oil pressure .. Valve train sounds like theres no oil going to it until it reaches operating temp ..then its faint on acceleration ,, any valve lash adjustments on these 4.2's ??
Old 09-22-2009, 07:19 PM
WOOLUF1952 WOOLUF1952 is offline
Magnetic Red Metallic 4.2L I6 4X4
The I-6 has no lifters. And, IIRC, there is no valve lash adjustment.
Old 08-23-2010, 03:13 PM
131,000k engine noisey until it warms up
posted a problem at 117k and i tried every snake oil remedy under the sun , truck has 131K on it now and still has a very loud tapping noise comeing from the cams , like it has several bad valve lash adjusters , good oil pressure , just clatters really bad when cold, and when its hot , it almost goes away completely . Engine runs good still , Time to pull it ?
Old 08-23-2010, 03:17 PM
petevw's Avatar
petevw petevw is offline
Red Jewel Tintcoat 4.2L I6 4X4
Originally Posted by Speedracer13090 View Post
.....when its hot , it almost goes away completely . Engine runs good still , Time to pull it ?
I have 178K+ on my '02, and also have the tapping noise when cold.
Are you sure it's the cam lobes hitting the valves? It may be the clicking that comes from the fan clutch....there's a valve in it that allows the silicone fluid to move. When it's cold, the valve "clicks".
Always remember: wherever you go, there you are!
PCM4less,HID,DRL killer,cabin air filter,Mobil 1,K&N,LED's,230K+,
Old 08-23-2010, 04:26 PM
Lifteer noise
I know what your talking about with the fan .. Allready had that issue , All fixed now , this is all on the top end , clattering , like no oil . had my head under the hood , put a crew driver to my ear and the head .. its the top end all right . I guess ill run and when it quits , ill let you all know what it was ! :-)
Old 06-24-2011, 11:31 PM
Uncle Jeff Uncle Jeff is offline
Pewter Metallic 4.2L I6 4X4
The 4.2 does have lifters, but the lash is pre-set by the length of the valve. The lifter is at one end of the rocker, and the valve at the other. The rocker is a roller type, and the cam lobe rides on the roller part of the lifter.
Old 06-24-2011, 11:37 PM
I was looking for some info as to why the lifters on my 4.2 are noisy. The noise first started when the engine was cold, and the truck had sat for a few days(when I say cold I mean -20 deg C). Now the clacking noise has started to get worse, and now it's 2 separate lifters.....Just wanted to see what other people were saying before I decided to pull the lifters. This is obviously a common problem.
Old 06-24-2011, 11:43 PM
I've run Mobil 1 5W30, since new, so it can't be oil related....(quality). It would be interesting to see where the main oil gallery that supplies the lifters is located...
Old 06-25-2011, 10:10 AM
vipergg's Avatar
vipergg vipergg is offline
2008 Isuzu Ascender
Midnight Metallic 4.2L I6 2WD
oil
Maybe try a different oil next time, I put M1 in a V6 once and the thing sounded like a diesel engine. Went back to a good grade dino oil and it sounded normal again .
Old 06-25-2011, 10:28 AM
gmcman's Avatar
gmcman gmcman is offline
Onyx Black 4.2L I6 4X4
Doesn't happen all the time but when I start mine cold I get about 5-10 clicks until oil pressure is up., even using M1.
You could try some BG MOA for reg changes, the Quick Clean or Engine Purge may be worth a try. I've never been a fan of engine flushes but hear these work well.
I'm going to try one at my next interval to see if it clears anything up.
Forgot to mention Auto Rx, may be the wiser choice but i'm still in the research phase....anyone that has had success with any of them please chime in.
http://www.auto-rx.com/
