Dome Light Help - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2013 Chevrolet Trailblazer > 2013+ Chevrolet Trailblazer Forum
2013+ Chevrolet Trailblazer Forum Discussion on the new upcoming 2013 Chevy Trailblazer
Old 03-02-2014, 09:31 AM
cinorx cinorx is offline
2002 Chevy TrailBlazer LS
Dome Light Help
I recently tried installing led bulbs onto my dome lights on my 02 tb. Right away I noticed that the bulb blew out and ever since neither of the dome lights work, but I can press the reading lights and does turn on. I cant quite seem to find the problem onto why my domes don't work. Any Ideas?
Old 03-02-2014, 11:10 AM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
Maybe dual filament,fuse to one of the circuit.
Old 03-02-2014, 11:21 AM
freddyboy61 freddyboy61 is offline
2004 GMC Envoy SLE XL
Summit White 4.2L I6 4X4
Check fuses #4 & 40 in rear fuse box. Courtesy lights are separate from reading lights, with separate fuses. If the fuses are good, you may have taken out the BCM. LED lights are polarized and should be inserted in the socket only one way.
[SIZE="2"][I]Freddyboy61[/I][COLOR="Blue"][/COLOR][/SIZE]
[U] [/U]
Old 03-02-2014, 03:32 PM
Joel1 Joel1 is offline
2005 Isuzu Ascender
Sandstone Metallic 4.2L I6 2WD
If an LED is inserted "backwards" it just won't do anything; its a diode. They don't have any resistance on their own. Check if there is a wattage for this LED light (resistor built in to it) or is it a plain old LED. Bulbs have resistance which is what gives their wattage at 12Volts. If the LED had a different resistance (lower or none) it could blow the fuse.
Old 03-03-2014, 08:57 PM
Thanks Guys
Freddy, where is the bcm located at exactly? I will look at the fuses you stated above.... You know ive never had a problem installing leds until I did the domes on the tb.
Joel, The bulb probably blew cuz I possibly installed it backwards. I know the bulbs I got are 12v.
But your guy's input will definitely help once I get that chance to look at my tb.
Thanks once again.
Old 03-07-2014, 11:16 AM
stellafin5 stellafin5 is offline
2002 GMC Bravada
Liquid Silver Metallic 6.0L LS2 V8 4X4
Check your fuse, I have the same issue before some time mine was the fuse issue so I am not sure about it but check your fuse.
