Intercooler internal cleaning methods - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2013 Chevrolet Trailblazer > 2013+ Chevrolet Trailblazer Forum
2013+ Chevrolet Trailblazer Forum Discussion on the new upcoming 2013 Chevy Trailblazer
Old 11-24-2014, 02:55 AM
Roiyco Roiyco is offline
2007 GMC Bravada
Bordeaux Red Metallic Other 4X4
Intercooler internal conduit often with sludge, gum and other dirt, not only the air flow path is narrowed, but also reduces the cooling heat exchange capacity, therefore, must also be maintained and cleaned. General annual or engine overhaul, repair welding tank while coping intercooler internal cleaning and inspection.
Cleaning method: a 2% aqueous solution containing soda (temperature should be 70-80 ℃) added to the cooler, fill, wait 15 minutes, seeing leaks water cooler place. If and should be overhauled, welding repair (like fellow tank); if there is no leakage of water, back and forth, repeated several times, will be poured lotion, then charge into a 2% aqueous solution of sodium carbonate containing rinse clean, until relatively clean up, reraise clean water (80-90 ℃) cleaning, until the release of water to clean up. As the cold external oil stains can also be cleaned with lye, is: will the oil soaked in lye place, brush clearing, until clean. After cleaning with compressed air to water intercooler within natural dry or blow dry or when installing the intercooler is not connected to the intercooler pipe connected to the engine performance car parts , start the engine, wait in the cold dry air outlet timeshare , draw a line on the engine intake manifold. If it is found within the intercooler core is extremely dirty, you should carefully check the air filter and air intake where there are loopholes in the pipeline, and troubleshooting.
