Engine miss - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2013 Chevrolet Trailblazer > 2013+ Chevrolet Trailblazer Forum
2013+ Chevrolet Trailblazer Forum Discussion on the new upcoming 2013 Chevy Trailblazer
Old 11-16-2015, 10:39 PM
tfc tfc is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Engine miss
between 1500 and 2000 rpms sometimes engine misses diagnostics said camshaft sensor. Replaced no further codes except coolant temp too low(huh?) which shouldn't affect timing. Mechanic said maybe camshaft or bearings but not doing this all the time. Happens sometimes on level ground,sometimes on hills.
Old 11-17-2015, 03:23 PM
robertgee robertgee is offline
Senior Member
2006 Chevy TrailBlazer LS
Sandstone Metallic 4.2L I6 4X4
If it's camshaft or bearings, as stated, it will be constant, not just some of the time.
Mechanic should understand that fact, for certain.
Old 11-17-2015, 03:25 PM
EnvoyBoy2004's Avatar
EnvoyBoy2004 EnvoyBoy2004 is online now
2004 GMC Envoy SLT
Graphite Metallic 4.2L I6 4X4
How many miles on the truck?
What is your temperature gauge indicating? It should be near or at 210 deg. If it is below 210 by 1 or 2 tics on the gauge, you need to change the thermostat. If the engine is running too cool, the catalytic converter will eventually clog because the computer is making the fuel mixture richer.
A miss can be plugs, ignition coil or bad gas, etc. Don't go changing expensive items before a solid diagnosis is known.
Old 11-19-2015, 09:12 AM
tfc tfc is offline
thank you
174000 miles temp gauge is at 150 to 155 checked lower hose not hot at all so i'm guessing it's the thermostat not opening. thank you all for your help.
Old 11-20-2015, 10:04 PM
tfc tfc is offline
a ok
replaced thermostat everythings working fine thanks everyone.
Old 11-20-2015, 11:20 PM
2004 GMC Envoy SLT
If you have been running with a bad thermostat for a long time, you may want to have the exhaust back pressure checked out.
Old 11-24-2016, 04:40 AM
FreightDog FreightDog is offline
2005 Chevy TrailBlazer LT
White 4.2L I6 4X4
Wow, ok. Im not.the.only one with the exact same problem! My 05 has a sperratic miss when under load usually at lower rpm. Sometimes idle is sketchy. P0128 code. Temp has been anywhere between 140-160ish. Fresh k&n, plugs [oem],TB is kinda dirty.. Thank you all, ill get to it asap.
