Headlights Out - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-23-2017, 08:15 AM
Formula1 Formula1 is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Headlights Out
Both of my low beam headlights stopped working at the exact same time. What are the chances of that! High beams work just fine. I checked the fuses under the hood and they are good. Are there more fuses somewhere else that I am missing.
Thanks, Chris
I have a 2005 Trailblazer 4.2
Old 01-23-2017, 08:53 AM
dh4645's Avatar
dh4645 dh4645 is offline
Senior Member
2005 Chevy TrailBlazer LT EXT
Thanks, Chris
I just had to do this last year (and had to drive home over an hour with high beams on) , it was some sort of relay fuse. You can't tell they are bad by looking at them. I think it was like $20 at AA or AZ.
Edit.
I think it was that first one.
Old 01-23-2017, 09:11 AM
Ranger160 Ranger160 is offline
2002 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Most likely the headlight relay under hood. Mine did this.
Sent from my SM-G920W8 using Tapatalk
Old 01-23-2017, 09:19 AM
Black 4.2L I6 4X4
I hope its just a relay. After reading a bit now, I see a few threads where there seemed to be no fix or maybe they just never reposed that it was the relay.
Old 01-23-2017, 09:53 AM
dh4645's Avatar
Senior Member
Well you are welcome.
Have a good day.
Old 01-23-2017, 10:28 AM
EnvoyBoy2004's Avatar
EnvoyBoy2004 EnvoyBoy2004 is offline
2004 GMC Envoy SLT
Graphite Metallic 4.2L I6 4X4
Do not buy any headlight relay module other than AC Delco, most other aftermarket units have been known to fail. The relay location is in the underhood fuse box at location #46. For a quick confirmation of it is actually bad, take relay from location #45 and install in location #46.
Old 01-23-2017, 09:28 PM
Black 4.2L I6 4X4
Ok I did the relay swap and it did not work
So, what are the chances that both relays are bad?
And thanks everyone for the help
Old 01-23-2017, 09:54 PM
Black 4.2L I6 4X4
Of the two relays mentioned 45 & 46 one is for the fan clutch the other is for the low beams. There is always a possibility that both are bad. Keep us posted.
Old 01-23-2017, 10:46 PM
Black 4.2L I6 4X4
I got 2 new relays.....does not work!
now I will try bulbs...but I just put in new ones 2 months ago.
I guess its possible.
Old 01-23-2017, 11:09 PM
2004 GMC Envoy SLT
Check fuses #3 & 6 in the underhood fuse box as well.
