Need Help In Diagnosing Bad Fan Clutch - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-18-2017, 03:57 PM
Robopredinator Robopredinator is offline
2002 GMC Envoy SLE
I have this bad squeaking near the front of the car that I thought was a belt or pulley issue. I took off the belt and noticed a bad rotational squeak when I turned the radiator fan. I'm hesitant to replace the fan clutch without fully knowing if the squeak is coming from elsewhere in the assembly. I do get the loud "jet turbine" noise at start up but I haven't read about anyone else noticing a rotational squeak in regards to their bad fan clutch.
Bad fan clutch or water pump? Both?
Thanks in advance.
Old 03-18-2017, 11:13 PM
EnvoyBoy2004's Avatar
EnvoyBoy2004 EnvoyBoy2004 is offline
2004 GMC Envoy SLT
Graphite Metallic 4.2L I6 4X4
I have never heard of the fan clutch showing mechanical noises, I would say it probably is the water pump. That being said, I would suggest changing both because of the work involved in doing either.
Old 03-30-2017, 01:21 PM
joric's Avatar
joric joric is offline
2003 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Swap em both out.. Fan clutch sounds like a jet whistling by when you rev the engine if its totally bad.. as a result the shaft on the water pump can go duff or will in the near future.. Autozone etc do a loaner tool fan clutch tool to hold the water pump pulley while you undo the fan's 1-1/2'' nut.
Look on youtube for a how to video.. takes about 2 hrs if you follow.. not that hard.
Joric
Your tricked out Honda sounds intrestin.. can I buy it..??.. the wife needs a new hairdryer..
Old 04-05-2017, 10:59 AM
aschaller2's Avatar
aschaller2 aschaller2 is offline
2002 Chevy TrailBlazer LS
Don't want to reiterate what everyone else said but its 100% the water pump. My fan clutch went out awhile ago and i just fixed it last week. Considering how big of a b**** it is to fix it I would also suggest replacing both while you have it all apart. Will save you a ton of stress in the future especially since the fan clutch is a common problem with these vehicles, chances are you will need to replace it sooner or later.
Old 04-05-2017, 07:44 PM
2002 GMC Envoy SLE
New day, new problems. I replaced the water pump and fan clutch and while I was in there, replaced the camshaft position sensor. The car will not start! I took the battery in to Autozone and they said it was no good after charging for an hour. I put in a new battery and the car still won't turn over.
Envoy is a 2002 year model and all the ignition coils have already been replaced. One thing that I do recall happening during the time the noise came about was the ABS light had came on. I forgot about this and just noticed it today when I tried starting it with the new battery.
Any insight, feedback or help?
Old 04-06-2017, 02:52 PM
treefiddy treefiddy is offline
2003 Chevy TrailBlazer LT EXT
Silver Green Metallic 4.2L I6 2WD
Thanks in advance.
I would say water pump for the squeaking. The bad fan clutch can hurt the water pump too, I think.
Do em both. It's an extra 10 minutes to do both, whichever you are replacing.
Old 05-19-2017, 12:53 PM
BigBizE BigBizE is offline
Sandalwood Metallic 5.3L V8 4X4
A bad camshaft position sensor can keep the car from starting. Why did you change it? Just curious. I had to replace my water pump this winter. I learned the hard way that you should replace the fan clutch at the same time because I ended up doing it a week later. Didn't think to mess with the camshaft sensor though. Maybe one of those situations where if it wasn't broken, it might've been best to leave it be...
Old 05-22-2017, 02:02 PM
unioncreek unioncreek is offline
2006 Chevy TrailBlazer LS
Put the old sensor back in if you still have it and see if it will start. If it doesn't return the new one and get another.
Bob
