Stuck in 4 Wheel Drive - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-19-2017, 07:40 AM
Gregory65's Avatar
Gregory65 Gregory65 is online now
2005 Chevy TrailBlazer LS
I have a 2005 Chevy Trailblazer. I have noticed it is stuck in 4 Wheel drive when driving on the freeway at 60 and 70 mph. The noise is loud, vibration in the front end and different feel in steering and suspension. The switch shows 2 wheel hi. When I cycle the switch, ABS, BRAKE and Service 4X4 lights come on. I have recently replaced my front hubs.
Sent from my SM-N910P using Tapatalk
Old 05-19-2017, 11:03 AM
EnvoyBoy2004's Avatar
EnvoyBoy2004 EnvoyBoy2004 is offline
2004 GMC Envoy SLT
Graphite Metallic 4.2L I6 4X4
It is very possible that the front Disconnect assembly is stuck in the engaged position or the actuator is stuck (that would cause the Service 4WD light).
What is the maintenance history on the transfer case fluid change? It should be changed every 50K miles.
The ABS and BRAKE warning should have no connection to 4WD system. Did you make sure that the speed sensors are properly connected?
Old 05-19-2017, 11:59 AM
Gregory65's Avatar
I bought it used last year with 88,000 and I do not see it has been serviced. The sensors a all connected. Like I said, the ABS, Brake and 4 wheel service lights come on when I cycle the 4 wheel drive switch.
Old 05-19-2017, 12:01 PM
Gregory65's Avatar
I am now at just under 102,000 miles. I was planning on doing a fluid change on the transfer case....
Old 05-20-2017, 05:01 PM
Gregory65's Avatar
I did change the transfer case fluid today. What drained was very dark and about 3/4 of a quart low. I filled it with AC Delco AutoTrac 2 fluid. The transfer case seems to be functioning normally. The problem appears to be the front axle locked. The switch started functioning with out switch indicators flashing. I got a new 4WD front axle actuator, but when trying to remove the old one, I found a strange size bolt for the 2 holding it. Videos and instructions say they are 8mm hex, mine are smaller. Tried a 7mm...almost worked. Tried SAE...too big or too small.
