2005 Envoy battery drains and weird sound - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 06-17-2017, 06:39 PM
juliaannsmith juliaannsmith is offline
2005 GMC Envoy SLE
Steel Gray Metallic 4.2L I6 2WD
My battery has been draining when it sits for 5 or more hours without starting. The ONLY thing I have found suspicious is a noise similar to a vacuum cleaner when the engine is on or off. I have had the battery alternator and starter tested. The sound seems to originate from the air intake, but can be heard under the car as well. It sounds just like a vacuum cleaner at a car wash! When it stops it even sounds like a vacuum turning off. I'm concerned that I am hearing this with the engine off. Is this happening while I'm away from the car and draining my battery?
Sent from my SAMSUNG-SM-T377A using Tapatalk
Old 06-18-2017, 11:50 PM
2005 GMC Envoy SLE
I figured out it was the air pump underneath the car beneath driver's seat. I don't know why it has been turning on. I pulled the fuse for now.
Old 06-19-2017, 02:15 PM
EnvoyBoy2004's Avatar
EnvoyBoy2004 EnvoyBoy2004 is offline
2004 GMC Envoy SLT
Graphite Metallic 4.2L I6 4X4
It probably is the relay that controls the air pump, check out the figure in the thread link below for location.
http://forums.trailvoy.com/showthread.php?t=143137
