We have a new batch of OEM Electronic Visco Fan Clutches for $159.00 this is the lowest Price on the Net for the part. We will run this special until Mid January or until we run out, whichever comes first. Shipping is a flat $10.00 within the continental US. You can contact us at 817 886-2521 or via the forum's Private Message system.
Your mechanic may also call it Electronic Fan clutch a Cooling Fan Speed Sensor or Electro-Viscous (EV) Fan Clutch. These terms are describing all the same part.
The fan clutch on the models above is known for high failure rates mostly due to the forces exerted on the wire attachment during the start up of the fan. The fan clutch normally needs to be replaced when the following error codes show P0495, P1481, P1482, P1484. Excessive fan noise is normally also a factor as is increased engine temperature and lower AC performance.
The fan clutches we are selling are made in the US by Behr, the OEM supplier for these clutches to GM. The clutches are the latest engineering version and are the same you can buy at the dealer for about $380. There are several other brands of clutches out there which are manufactured in Korea. While the quality of the Korean clutches is good, they are not set to the same specs decreasing fuel efficiency and increasing noise. You can find the Korean copies for about the same price we are offering the real thing for. The manufacturers of the European copies literally copied the older versions with all it flaws and shortcomings. Why not stay with a brand that car owners and manufacturers have trusted for decades.
Our clutch replaces the following brands and part numbers:
* Platinum #: 2120000
* Dorman #: 622-001
* Hollander #: 326-748
* OE #: 15293048, 15192192, 15116115, 10383029, 25790869
The clutch is the latest revision, part number 25790869.
In certain instances the PCM of your vehicle might need to be reflashed with the latest software. Please check with your dealer or repair shop.
The repair can normally be done by everyone with some mechanical aptitude. Autozone rents out the fan clutch removal wrench that can aid in the repair. A brief set of instructions on how to change the fan clutch can be found here: http://wiki.answers.com/Q/How_do_you_change_a_fan_clutch_on_a_2002_Chevy_Trailblazer_LT
(As usual the disclaimer, these instructions are not our own and have not been verified by a certified mechanic. If you feel uncomfortable with the instructions or the work described within please have the fan clutch replaced by a professional mechanic. We are not responsible for any damage or injury.)
See below for a listing of all applications of the clutch:
Year Make Model Engine Application Note
# 2006 SAAB 9-7X: 5.3I V8 - 5.3L (325 CID): GAS: FI: N Electric
# 2006 SAAB 9-7X: 4.2I L6 - 4.2L (256 CID): GAS: FI: N Electric
# 2006 ISUZU ASCENDER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 ISUZU ASCENDER: LS V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 ISUZU ASCENDER: LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMC S15 ENVOY: XL SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMCS15 ENVOY: XL SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMC S15 ENVOY: XL DEN V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 GMC S15 ENVOY: SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMC S15 ENVOY: SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMC S15 ENVOY: DENALI V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 CHEVROLETS10 TRAILBLAZER: SSV8 - 6.0L (364 CID): GAS: FI: N: H Electric
# 2006 CHEVROLETS10 TRAILBLAZER: LT V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 CHEVROLETS10 TRAILBLAZER: LT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 CHEVROLETS10 TRAILBLAZER: LS V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 CHEVROLET S10 TRAILBLAZER: LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 CHEVROLET S10 TRAILBL.: EXT LTV8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 CHEVROLETS10 TRAILBL: EXT LT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 CHEVROLETS10 TRAILBL.: EXT LS V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 CHEVROLET S10 TRAILBL.: EXT LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 BUICK RAINIER: CXL V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 BUICK RAINIER: CXL L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 ISUZU ASCENDER: S V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 ISUZU ASCENDER: S L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 ISUZU ASCENDER: LS V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 ISUZU ASCENDER: LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 ISUZU ASCENDER: LIMITED V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 GMC S15 ENVOY: XUV SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: XUV SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: XL SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: XL SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 CHEVROLET S10 TRAILBLAZER: LTL6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 CHEVROLET S10 TRAILBLAZER: LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 CHEVROLET S10 TRAILBL.: EXT LT V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 CHEVROLET S10 TRAILBL.: EXT LT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 CHEVROLET S10 TRAILBL.: EXT LS V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 CHEVROLET S10 TRAILBL.: EXT LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 BUICK RAINIER V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 BUICK RAINIER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 OLDSMOBILE BRAVADA L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 ISUZU ASCENDER V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2004 ISUZU ASCENDER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 GMC TRUCK S15 ENVOY L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 GMC TRUCK S15 ENVOY: XUV V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2004 GMC TRUCK S15 ENVOY: XUV L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 GMC TRUCK S15 ENVOY: XL V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2004 GMC TRUCK S15 ENVOY: XL L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 CHEVROLET S10 TRAILBLAZER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 CHEVROLET S10 TRAILBL.: EXT V8 - 5.3L (325 CID): GAS: FI: N: P Electric
# 2004 CHEVROLET S10 TRAILBL.: EXT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 BUICK RAINIER V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2004 BUICK RAINIER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 OLDSMOBILE BRAVADA L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 ISUZU ASCENDER V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2003 ISUZU ASCENDER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 GMC TRUCK S15 ENVOY L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 GMC TRUCK S15 ENVOY: XL V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2003 GMC TRUCK S15 ENVOY: XL L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 CHEVROLET S10 TRAILBLAZER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 CHEVROLET S10 TRAILBL.: EXT V8 - 5.3L (325 CID): GAS: FI: N: P Electric
# 2003 CHEVROLET S10 TRAILBL.: EXT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2002 OLDSMOBILE BRAVADA L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2002 GMC TRUCK S15 ENVOY L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2002 GMC TRUCK S15 ENVOY: XL L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2002 CHEVROLET S10 TRAILBLAZER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2002 CHEVROLET S10 TRAILBL.: EXT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
If you own an BMW, Mercedes, Mini, Volvo or Porsche feel free to visit our European Parts Store at EuroPartsAmerica.com.
