2005 TB engine issue - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-16-2017, 08:13 AM
joe70ss joe70ss is offline
Graystone Metallic 4.2L I6 4X4
Friend has 2005 Tb with no codes showing but the car seems like it is running on only 5 cylinder,any help thanks
Old 02-16-2017, 12:23 PM
Pull connector off one coil pack at time and see if running gets worse. If one does not make it worse, then that cylinder has a problem; coil pack, spark plug, compression or injector.
Old 02-17-2017, 06:45 AM
Thanks Bad coil pack
Old 02-19-2017, 11:20 AM
went coil pack went bad there was no code,just showed a misfire,why no code like a 601?
Old 02-19-2017, 02:49 PM
The PCM doesn't call out a bad cylinder unless there is a required number of misfires within a certain time.
Old Yesterday, 06:44 PM
Thanks,any idea on the lock problem I have listed Thanks
Old Yesterday, 07:53 PM
What lock problem? Don't see anything in the post.
Old Today, 09:26 AM
Back with door locks,no code
can lock doors with key,but can NOT unlock with key
Both FOB do NOT work,changed battery
car does lock when you drive at 15MPH
Any ideas THANKS
