this should help
i found this in the articles section of the site there are pics there too that may help..
Step 13) Now that we've installed the fog lights between the bumper and the frame, we have to wire them up. There are several options:
First, you could wire them to any of the lights already present in the front with a relay.
Second, you could utilize the fog light relay and fuse that are already in the fuse box under the hood.
Third, you could pull wires through the firewall.
Option 1 is definately the easiest. All you have to do is add a T-tap to the correct wire, in our case we connected the fog light control to the (+) low beam. Then connect this T-tap to the coil on the relay and ground the other side. At this point you would need power for the fog lights which will be switched by the relay that was just described. The fusebox under the hood has a simple spot where you can simply add a ring with a wire to connect to battery (+). In this wire I suggest you add fuses. We used a 20amp fuse. Now the second wire you need is ground. You could connect this to the frame or the battery itself. Make sure that you can get a good contact and always test the ground after you install it with a multi-meter. This method allows you to have the fog lights automatically come on with the low beams.
Option 2 is a bit harder, however this would allow you to make it look more stock. You can solder on the bottom of the fuse box the wiring for the fog lights, everything should be present except for the wiring harness to the fog lights. After you've connected the fog lights to the fuse box you have several options for how to control them. At the BCM you could connect the foglight relay control with the lowbeam relay control, this would essentially work the same as method one, except you connect the lowbeams and foglights at the BCM. The other option is that you buy the stock headlight switch with fog light control. This will not work straight out of the box, to have it work completely OEM the dealership has to reprogram the BCM so that it will interpret the fog light signal and switch the foglight relay control accordingly. However, one could just cut the foglight relay control @ the BCM and T-tap it to the foglight control signal. This way the BCM does not have to be reprogrammed, plus the fog lights will then not turn off when you turn your high beams on. If you do want your fog lights to turn off when your highbeams turn on, just add a relay and connect the relay's coil to the high beam relay control.
Option 3 is very similar to the first option, except instead of using a light signal, we pull 1 or 2 wires through the firewall and put a switch behind it, this will look the least OEM of them all. You can however, get the OEM light switch with fog light control and wire the fog light signal to a relay to control them behind the dash and pull the wires for this through the firewall. This would work the same as the second option, this way you don't have to mess with the wiring at the BCM. However, this way you do have to pull 1 or 2 wires through the firewall.
We wired the foglights to the lowbeams as described in the first option. Here is a quick overview / diagram of how we need to wire it up:
This is a quick overview of how we need to wire the headlights. You have to connect the right foglights (left in the picture) to the left side of the car (right in the picture). We did this by guiding the wire up to the right headlight (left in the picture) and then guiding wire along the existing light wiring harness it through the tube right behind/below the grill to the left side of the car (right in the picture). The left foglight is pulled up the headlight wiring on the left (right in the picture). Both of these foglights are then spliced together and connected at a relay. This relay is switched via the low beam signal which inturn can connect the battery (+) to the foglights when the lowbeams are on. The ground is always connected. For the lowbeam signal, check the wires on the connector on the headlights and test with a multimeter which is the lowbeam signal wire
Above, you can see the right foglight wiring going up to the headlight wiring where it is guided through a tube that was already present to the other side.
At the left headlight connector we connected a green wire to the lowbeam signal, we then connected this to the connector allowing us to disable the fog lights if needed simply by disconnecting this connector. (You can see this connector right above the left headlight connector). This signal then leads to the coil on the relay and the other side is connected to ground (leads off to the right along with the batt(+) between the fender and the battery to the fusebox under the hood. The left and right foglights are spliced together and are connected directly to ground and the other side is connected to the switched battery(+) on the relay.
This is between the battery and the fusebox under the hood. You can see where the wire connects to the battery (+) under the fusebox cover, and the ground connects to the bolt against the fender.
-Source: ewoutvb.com
