Ok so I just replaced all me Dome Lights except the rear with 6000k LED These are the LEDs I used
They work amazing when you open the door or use the dimmer switch to turn them on but if you click the light they come on extremely dim.
Ill post the Lumen output of each mode later tonight. I threw a multi meter on it and when I click the button it is clearly a lower voltage ( about 1-2v) going through the light than when I use the dimmer switch or the door. I didn't know if the switch it self has a resistor in it and if it did if it could be removed
Thanks in advanced for any and all help
TJ
TJ
