Vin Comparisions
587K views 2K replies 694 participants last post by  flyboy2610
#1 ·
Can somebody run a vin comparision between these two vins (1GNDT13S132263190 and 1GNDT13S522492535) based on the BCM program since i am trying to do a vin swap so that I can change the BCM program. I like to know the difference between these vins. Thanks
#2 ·
Report Run Date: 2009-01-02 21:08:06.536 EST
The vehicle identification number you submitted has been analyzed and summary information on your car is shown below.
VIN: 1GNDT13S132263190
Year: 2003
Make: Chevrolet
Model: Trailblazer LS / LT / LTZ / North Face
Style/Body: SUV / Utility 4D
Class: SUV - Lower Mid Range
Engine: 4.2L I6 MPI / SFI
Country of Assembly: United States
Vehicle Age: 6 year(s)
Calculated Owners: 2
Last Reported
Odometer Reading: 34,504
Report Run Date: 2009-01-02 21:09:04.554 EST
VIN: 1GNDT13S522492535
Year: 2002
Make: Chevrolet
Vehicle Age: 7 year(s)
Last Reported
Odometer Reading: 41,694
#4 ·
VIN 1GNDT13S132263190
VEHICLE BUILD
Merchandising Model : CT15506 -2003 TRAILBLAZER LTZ 4WD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : FVVXSX
Build Date : 01/15/2003 Build Plant : 13206
OPTION CODES
AAB - MEMORY DRIVER CONVENIENCE PKG AJ1 - DEEP TINTED GLASS
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG AM9 - SPLIT FOLDING REAR SEAT BACK
AP9 - CARGO CONVENIENCE NET AR9 - FRT BUCKET SEAT, DELUXE
AU0 - KEYLESS REMOTE DOOR LOCK AXP - MPV VIN IDENT POSITION
BVE - SIDE RUNNING BOARD STEPS B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS
B42 - REVERSIBLE CARPET/VINYL CARGO UTILITY MAT CF5 - ELECTRIC SLIDING SUNROOF (INCLUDES $250 SAVINGS FOR SUNROOF & ONSTAR)
CJ2 - AUTOMATIC CLIMATE CONTROL C49 - ELECTRIC REAR WINDOW DEFOGGER
C5N - GVW RATING - 5750 LBS DAY - ASSEMBLY PLANT MORAINE, OHIO
DD7 - ISRV MIRROR W/COMPASS DH2 - LIGHTED LH & RH VISOR MIRRORS
DK7 - OVERHEAD CONSOLE EQUIP ADJ DS3 - MIRROR LH/RH REMOTE
EVA - EVAP EMISSION REQUIREMENT FE9 - 50-STATE EMISSIONS
GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING DIFFERENTIAL-REAR AXLE
JF8 - BRAKE VAC POWER, 4 WHL DISC KA1 - HEATED FRONT SEATS
KG4 - GENERATOR 150 AMP K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
LL8 - VORTEC 4200 SFI I6 M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NF7 - FEDERAL EMISSION SYSTEM NLEV NNK - EXTENDED CAPACITY FUEL TANK
N40 - POWER STEERING N74 - 17" ALUMINUM SPORT WHEEL
N79 - FULL SIZE SPARE QTR - P245/65R17 FOUR ON/OFF ROAD WOL TIRES (REPLACES STD/OPT PKG TIRES)
RYJ - RETRACTABLE CARGO AREA COVER R7C - EXPEDITE PROCESSING OF ORDERS
R9U - GM ACCESS - AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
STW - LEATHER WRAPPED STEERING WHEEL W/CONTROLS TB4 - LIFTGATE
T61 - DAYTIME RUNNING LIGHTS T96 - FRONT FOG LAMPS
T98 - STAMPING VEHICLE IDENT NUMBER UA6 - THEFT DETERRENT ALARM SYSTEM
UC6 - AM/FM RADIO,RDS,6 DISC CHANGER, AUTO TONE CONTROL, AND ETR (REPLACES STD/OPT PKG RADIO) UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN
UG1 - HOMELINK UK6 - RADIO CONTROLS RR ST & EARPHONE
UPC - TRAVEL NOTE UY7 - TRAILER WIRING HARNESS
U68 - DRIVER INFO CENTER DISPLAY U73 - FIXED MAST ANTENNA
VK3 - FRONT LICENSE PLATE MOUNT VXS - COMPLETE VEHICLE LABEL
V1K - LUGGAGE RACK CROSS-BARS V40 - POWER PASSENGER SEAT PROVISIONS
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA V76 - TOW HOOKS
X88 - CHEVROLET CONVERSION YC6 - LTZ DECOR
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING ZM5 - UNDERBODY SHIELD PACKAGE
ZQ3 - DRIVER CONVENIENCE PACKAGE: DRVR MESSAGE CNTR, AUTO CLIMATE CONTROL, RR SEAT RADIO AND HVAC CTRLS. LEATHER STRG WHL W/CONTL ZW7 - PREMIUM RIDE SUSPENSION
ZY7 - TWO-TONE APPEARANCE 1SF - LTZ PREFERRED EQUIPMENT GROUP 1
11L - LT PEWTER METALLIC 39U - INDIGO BLUE METALLIC
6SK - COMP FRT LH COMPUTER SEL SUSP 7SJ - COMP FRT RH COMPUTER SEL SUSP
8EX - COMP RR LH COMPUTER SEL SUSP 9EW - COMP RR RH COMPUTER SEL SUSP
92I - DK PEWTER/DK PEWTER INT TRIM 922 - DK PEWTER/DK PEWTER ACCENTS
VIN 1GNDT13S522492535
VEHICLE BUILD
Merchandising Model : CT15506 -2002 TRAILBLAZER LTZ 4WD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : FDHRMJ
Build Date : 05/21/2002 Build Plant : 12206
OPTION CODES
AJ7 - DR/PASS FRT & SIDE AIRBAGS AM9 - SPLIT FOLDING REAR SEAT BACK
AP9 - CARGO CONVENIENCE NET AR9 - FRT BUCKET SEAT, DELUXE WITH LEATHER SEATING SURFACES
AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER AXP - MPV VIN IDENT POSITION
BVE - SIDE RUNNINGBOARD STEPS B30 - WHEELHOUSING & FLOOR CARPETING
CE1 - RAIN SENSING WIPERS CF5 - ELECTRIC SUNROOF
DD7 - ISRV MIRROR W/COMPASS DK7 - OVERHEAD CONSOLE EQUIP ADJ (DELETE TRAVEL NOTE)
D25 - MIRROR O/S LH & RH, REMOTE CTL, ELECTRIC, HEATED W/TURN SIG IND EVA - EVAP EMISSION REQUIREMENT
FE9 - 50-STATE LOW EMISSION VEHICLE GT4 - REAR AXLE - 3.73 RATIO
G80 - LOCKING DIFFERENTIAL-REAR AXLE JF8 - BRAKE VAC POWER, 4 WHL DISC
KA1 - HEATED FRONT SEATS KG4 - GENERATOR 150 AMP
K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED LL8 - VORTEC 4200 SFI I6
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
N79 - FULL SIZE SPARE QTR - P245/65R17 ALL-SEASON WOL ON-/ OFF ROAD TIRES
RYJ - RETRACTABLE CARGO AREA COVER SLM - STOCK ORDERS
UC6 - AM/FM RADIO,RDS,6 DISC CHANGER, AUTO TONE CONTROL, AND ETR UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN
UPC - TRAVEL NOTE UQA - BOSE PREMIUM SOUND SYSTEM
V40 - POWER PASSENGER SEAT PROVISIONS V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
YD6 - BASE REAR SPRING ZQ3 - DRIVER CONVENIENCE PACKAGE: DRVR MESSAGE CNTR, AUTO CLIMATE CONTROL, RR SEAT RADIO AND HVAC CTRLS. LEATHER STRG WHL W/CONTL
ZW7 - PREMIUM RIDE SUSPENSION ZY1 - SOLID EXTERIOR APPEARANCE
1SF - LTZ PREFERRED EQUIPMENT GROUP 1 39U - INDIGO BLUE METALLIC
8EZ - COMP RR LH COMPUTER SEL SUSP 9EX - COMP RR RH COMPUTER SEL SUSP
#5 ·
VEHICLE BUILD
OPTION CODES
VEHICLE BUILD
OPTION CODES
Thanks! OMG i thought i had 3.42 gear but i actually have 3.73. no wonder i have bad mileage.:bonk:
Now with all the info above, is it possible to remove this code on the BCM "AJ7 - DR/PASS FRT & SIDE AIRBAGS" and switch it to this "AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG" BCM code from the dealer??
#8 ·
You also have open recall on this vin.
Type Number Description Posted Date Status
RC 02032 DRIVER SIDE DUAL STAGE AIRBAG INFLATOR 08/13/2002 Open
RC 03012 TRANSMISSION SHIFT LOCK AND IGNITION KEY REMOVAL OVERRIDE COMPLIANCE 05/21/2003 Open
RC 04005 WINDSHIELD WIPER MOTOR FAILURE 07/06/2004 Open
RC 04087 TAIL LAMPS/STOP LAMPS 11/16/2004 Open
VIN 1GNDS13S222499428
VEHICLE BUILD
Merchandising Model : CS15506 -2002 TRAILBLAZER LS 2WD
Gross Vehicle Weight Rating : 2520 kg (5557 lb) Order Number : FDZV2B
Build Date : 05/29/2002 Build Plant : 12206
OPTION CODES
AJ1 - DEEP TINTED GLASS AJ7 - DR/PASS FRT & SIDE AIRBAGS
AM9 - SPLIT FOLDING REAR SEAT BACK AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AXP - MPV VIN IDENT POSITION A50 - FRONT RECLINING BUCKET SEATS WITH FLOOR CONSOLE
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B86 - MOLDING B/S COLOR
CJ3 - CLIMATE CONTROL C4D - GVW RATING - 5550 LBS
C49 - ELECTRIC REAR WINDOW DEFOGGER DAY - ASSEMBLY PLANT MORAINE, OHIO
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER EVA - EVAP EMISSION REQUIREMENT
LL8 - VORTEC 4200 SFI I6 M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NF7 - FEDERAL EMISSION SYSTEM NLEV NP5 - LEATHER WRAPPED STEERING WHEEL
N40 - POWER STEERING N86 - FULL SIZE SPARE
QC4 - 16" ALUMINUM WHEEL QRE - P245/70R16 BW ALL SEASON TIRES
TB4 - LIFTGATE T61 - DAYTIME RUNNING LIGHTS
UP0 - AM/FM STEREO W/CASS & CD PLAYER U73 - FIXED MAST ANTENNA
VP6 - NOISE CONTROL VXS - COMPLETE VEHICLE LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA X88 - CHEVROLET CONVERSION
YD6 - BASE REAR SPRING ZW7 - PREMIUM RIDE SUSPENSION
ZY1 - SOLID EXTERIOR APPEARANCE 1SC - LS PREFERRED EQUIPMENT GROUP 3 * POWER HEATED MIRRORS * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS W/DEEP TINT REAR * CRUISE CONTROL * BODY SIDE MOLDING * LEATHER WRAPPED STEERING WHL * REAR RETRACTABLE COMPARTMENT SHADE * THEFT DETERRENT SYSTEM * REMOTE KEYLESS ENTRY
50U - SUMMIT WHITE 6SH - COMP FRT LH COMPUTER SEL SUSP
7SG - COMP FRT RH COMPUTER SEL SUSP 8EU - COMP RR LH COMPUTER SEL SUSP
9ET - COMP RR RH COMPUTER SEL SUSP 95D - MED PEWTER/DK PEWTER ACCENTS
95I - MED PEWTER/DK PEWTER INT TRIM
#14 ·
for the AJ7 option i notice on the picture it contains signal side mirrors but what about the heated and light sensitive options??
#17 ·
VIN 1GNDT13S622335550
VEHICLE BUILD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : DSWTSM
Build Date : 12/03/2001 Build Plant : 12206
OPTION CODES
CE1 - RAIN SENSING WIPERS CJ2 - AUTOMATIC CLIMATE CONTROL
C49 - ELECTRIC REAR WINDOW DEFOGGER C5N - GVW RATING - 5750 LBS
DAY - ASSEMBLY PLANT MORAINE, OHIO DD7 - ISRV MIRROR W/COMPASS
DK7 - OVERHEAD CONSOLE EQUIP ADJ (DELETE TRAVEL NOTE) D25 - MIRROR O/S LH & RH, REMOTE CTL, ELECTRIC, HEATED W/TURN SIG IND
EVA - EVAP EMISSION REQUIREMENT FE9 - 50-STATE LOW EMISSION VEHICLE
GT4 - REAR AXLE - 3.73 RATIO JF8 - BRAKE VAC POWER, 4 WHL DISC
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN UG1 - HOMELINK
UK6 - RADIO CONTROLS RR ST & EARPHONE UPC - TRAVEL NOTE
UP0 - AM/FM STEREO W/CASS & CD PLAYER UQA - BOSE PREMIUM SOUND SYSTEM
U42 - REAR SEAT ENTERTAINMENT SYSTEM U68 - DRIVER INFO CENTER DISPLAY
U73 - FIXED MAST ANTENNA VXS - COMPLETE VEHICLE LABEL
1SF - LTZ PREFERRED EQUIPMENT GROUP 1 11U - LT PEWTER METALLIC
#19 ·
VIN 1GNES16S056151513
VEHICLE BUILD
Merchandising Model : CS15806 -2005 TRAILBLAZER EXT LT 2WD
Gross Vehicle Weight Rating : 2815 kg (6207 lb) Order Number : HPHC7R
Build Date : 11/17/2004 Build Plant : 15606
OPTION CODES
AJ1 - DEEP TINTED GLASS AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAG
AL0 - SENSOR INF RESTR, CHILD DETECT AM7 - FOLDING REAR SEAT
AM9 - SPLIT FOLDING REAR SEAT BACK AR9 - FRT BUCKET SEAT, DELUXE
A34 - POWER REAR QUARTER WINDOWS B30 - CARPETING, COLOR-KEYED
B32 - FLOOR MATS, FRONT AND REAR B33 - REAR COLOR KEYED FLOOR MATS
B8V - GM PRODUCTION WEEK #46 CJ3 - CLIMATE CONTROL
C49 - REAR WINDOW DEFOGGER DD5 - ISRV MIRROR W/COMPASS & TEMP
DH2 - LIGHTED LH & RH VISOR MIRRORS DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER
DK7 - OVERHEAD CONSOLE EVA - EVAP EMISSION REQUIREMENT
FLT - FLEET PROCESSING OPTION GU6 - REAR AXLE 3.42 RATIO
JF8 - BRAKE VAC POWER, 4 WHL DISC JJB - PT DRESS SUBASSY NOT INSTALLED
KG4 - GENERATOR 150 AMP KR8 - CAPPS VAN & TRUCK RENTAL
K34 - CRUISE CONTROL LL8 - VORTEC 4200 SFI I6
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL NF4 - EMISSIONS CLEAN FUEL FLEET
N40 - POWER STEERING N75 - 17" SPORT ALUMINUM WHEELS
N79 - FULL SIZE SPARE OKL - PLANT - OKLAHOMA CITY
QTE - P245/65R17 FOUR ON/OFF ROAD BLACKWALL TIRES Q4B - 6,200 LB GVW RATING
R6F - IDENTIFY B CODE USERS R6Q - SUN, SOUND AND ENTERTAINMENT PACKAGE NOT DESIRED
R6Y - ONSTAR PLUS PACKAGE NOT DESIRED TB4 - LIFTGATE
TFD - RETAIL AMENITY DELETE T61 - DAYTIME RUNNING LIGHTS
T96 - FRONT FOG LAMPS T98 - STAMPING VEHICLE IDENT NUMBER
UA6 - THEFT DETERRENT ALARM SYSTEM UB0 - AM/FM STEREO W/CD
UG1 - HOMELINK UY7 - TRAILER WIRING HARNESS
U42 - REAR SEAT ENTERTAINMENT SYSTEM U73 - FIXED MAST ANTENNA
VCL - 50-STATE EMISSIONS-CFF LEV VFF - VIDEO FORMAT REGION 1 NTSC
VK3 - LICENSE PLATE FRAME, FRONT VN9 - DAILY RENTAL REPURCHASE PROGRAM
VXS - COMPLETE VEHICLE LABEL V1K - LUGGAGE RACK CROSS-BARS
YC5 - LT DECOR YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
YT6 - IDENT, DAILY RENTAL FLAT DEPREC ZW7 - PREMIUM RIDE SUSPENSION
ZY1 - SOLID PAINT 1SD - LT PREFERRED EQUIPMENT GROUP 1
1SZ - PREFERRED EQUIPMENT SAVINGS 27H - LIGHT CASHMERE/EBONY
27I - INT TRIM CASHMERE/EBONY 50U - SUMMIT WHITE
6HB - SUSPENSION 7HB - SUSPENSION
8HT - COMP RR RH COMPUTER SEL SUSP 9HT - COMP RR RH COMPUTER SEL SUSP
#21 ·
Here ya go. What are you trying to accomplish?
VIN 1GNDT13S932190005
VEHICLE BUILD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : FQQCKW
Build Date : 10/16/2002 Build Plant : 13206
OPTION CODES
B33 - REAR COLOR KEYED FLOOR MATS B42 - REVERSIBLE CARPET/VINYL CARGO UTILITY MAT
CF5 - ELECTRIC SLIDING SUNROOF (INCLUDES $250 SAVINGS FOR SUNROOF & ONSTAR) CJ2 - AUTOMATIC CLIMATE CONTROL
DH2 - LIGHTED LH & RH VISOR MIRRORS DK7 - OVERHEAD CONSOLE EQUIP ADJ
DS3 - MIRROR LH/RH REMOTE EVA - EVAP EMISSION REQUIREMENT
FE9 - 50-STATE EMISSIONS GT4 - REAR AXLE - 3.73 RATIO
R7C - EXPEDITE PROCESSING OF ORDERS R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS STW - LEATHER WRAPPED STEERING WHEEL W/CONTROLS
UA6 - THEFT DETERRENT ALARM SYSTEM UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN
UPC - TRAVEL NOTE UP0 - AM/FM STEREO W/CASS & CD PLAYER
UY7 - TRAILER WIRING HARNESS U68 - DRIVER INFO CENTER DISPLAY
U73 - FIXED MAST ANTENNA VK3 - FRONT LICENSE PLATE MOUNT
V76 - TOW HOOKS X88 - CHEVROLET CONVERSION
YC6 - LTZ DECOR YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
6SJ - COMP FRT LH COMPUTER SEL SUSP 7SH - COMP FRT RH COMPUTER SEL SUSP
8EW - COMP RR LH COMPUTER SEL SUSP 9EU - COMP RR RH COMPUTER SEL SUSP
#26 ·
VIN 1GNDT13SX32202694
VEHICLE BUILD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : FSBJZS
Build Date : 10/30/2002 Build Plant : 13206
OPTION CODES
CE1 - RAIN SENSING WIPERS CF5 - ELECTRIC SLIDING SUNROOF (INCLUDES $250 SAVINGS FOR SUNROOF & ONSTAR)
EVA - EVAP EMISSION REQUIREMENT GT4 - REAR AXLE - 3.73 RATIO
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL NC1 - CALIFORNIA EMISSIONS LEV
NNK - EXTENDED CAPACITY FUEL TANK N40 - POWER STEERING
N74 - 17" ALUMINUM SPORT WHEEL N79 - FULL SIZE SPARE
QTR - P245/65R17 FOUR ON/OFF ROAD WOL TIRES (REPLACES STD/OPT PKG TIRES) RYJ - RETRACTABLE CARGO AREA COVER
U73 - FIXED MAST ANTENNA VG8 - NOTICE TO BUYER LABEL
VK3 - FRONT LICENSE PLATE MOUNT VP6 - NOISE CONTROL
YA7 - CALIF. ASSY. LINE EMISSION TEST YC6 - LTZ DECOR
YD6 - BASE REAR SPRING YF5 - 50-STATE EMISSIONS
11L - LT PEWTER METALLIC 50U - SUMMIT WHITE
8EX - COMP RR LH COMPUTER SEL SUSP 9EU - COMP RR RH COMPUTER SEL SUSP
#23 ·
well based on the results 02 LTZ all contain side airbags w/ all side mirror features but 03 LTZ do not contain side air bags w/ only signal side mirrors only.
Thanks for your help Mark!
#28 ·
If its not a problem i was wondering if you could run this vin for me looking at the glove box it doesnt seem i have too many options that i actually wanted :( lol. Thanks.
1gndt13s152378049
VIN 1GNDT13S152378049
VEHICLE BUILD
Merchandising Model : CT15506 -2005 TRAILBLAZER LS 4WD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : JDCZT5
Build Date : 06/22/2005 Build Plant : 15206
OPTION CODES
AL0 - SENSOR INF RESTR, CHILD DETECT AM9 - SPLIT FOLDING REAR SEAT BACK
AR9 - FRT BUCKET SEAT, DELUXE AU0 - KEYLESS REMOTE DOOR LOCK
AXP - MPV VIN IDENT POSITION B30 - CARPETING, COLOR-KEYED
B84 - BODY SIDE MOLDINGS CF5 - ELECTRIC SUNROOF
CJ3 - CLIMATE CONTROL C49 - REAR WINDOW DEFOGGER
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER DK7 - OVERHEAD CONSOLE
DT4 - ASHTRAY AND LIGHTER EVA - EVAP EMISSION REQUIREMENT
GU6 - REAR AXLE 3.42 RATIO JF8 - BRAKE VAC POWER, 4 WHL DISC
JJB - PT DRESS SUBASSY NOT INSTALLED KG4 - GENERATOR 150 AMP
K18 - ELECTRIC AIR INJECTION SYSTEM K34 - CRUISE CONTROL
NE1 - 50-STATE EMISSIONS NP8 - 2-SPEED ACTIVE TRANSFER CASE
NU1 - EMISSION, CALIFORNIA LEV2 NZ3 - FULL SIZE SPARE
N40 - POWER STEERING PCK - ONSTAR PLUS PACKAGE
PCR - SUN, SOUND, AND ENTERTAINMENT PACKAGE * POWER SUNROOF * BOSE PREMIUM SOUND SYSTEM * XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT. SERVICE FEE EXTRA 1ST 3MO INC * AM/FM STEREO W/6 DISC CHANGER (REPLACES STD/OPT PKG RADIO) * CUSTOM O/H CONSOLE PDC - SEAT, 8-WAY POWER DRIVER
QC3 - ALUMINUM WHEELS QNG - P235/75R16 FOUR ALL SEASON WOL TIRES
R7E - INTERIM PRICE DECREASE R9C - ONSTAR & CRUISE MADE STANDARD
SLM - STOCK ORDERS TB4 - LIFTGATE
T61 - DAYTIME RUNNING LIGHTS T98 - STAMPING VEHICLE IDENT NUMBER
UA6 - THEFT DETERRENT ALARM SYSTEM UC6 - AM/FM RADIO,RDS,6 DISC CHANGER, (REPLACES STD/OPT PKG RADIO)
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND UQA - BOSE PREMIUM SOUND SYSTEM
UY7 - TRAILER WIRING HARNESS U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT. SERVICE FEE EXTRA.1ST 3MOS.INCL
U73 - FIXED MAST ANTENNA VK3 - LICENSE PLATE FRAME, FRONT
X88 - CHEVROLET CONVERSION YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
ZW7 - PREMIUM RIDE SUSPENSION ZY1 - SOLID PAINT
1SB - LS PREFERRED EQUIPMENT GROUP 2 * POWER MIRRORS, HEATED * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS * BODY SIDE MOLDING * TOW HOOKS * LUGGAGE RACK CROSS BARS * TRAILER WIRING CONNECTOR * REMOTE KEYLESS ENTRY * THEFT DETERRENT SYSTEM 1SZ - PREFERRED EQUIPMENT SAVINGS
27H - LIGHT CASHMERE/EBONY 27I - INT TRIM CASHMERE/EBONY
41U - BLACK 6HP - SUSPENSION
7HP - SUSPENSION 8NS - SUSPENSION
9NS - SUSPENSION
#30 ·
Help
VIN 1GNDT13SX22227920
VEHICLE BUILD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : DMQD2H
Build Date : 08/13/2001 Build Plant : 12206
OPTION CODES
FE9 - 50-STATE LOW EMISSION VEHICLE GU6 - REAR AXLE 3.42 RATIO
NF7 - FEDERAL EMISSION SYSTEM NLEV N40 - POWER STEERING
QTR - P245/65R17 ALL-SEASON WOL ON-/ OFF ROAD TIRES RYJ - RETRACTABLE CARGO AREA COVER
UQA - BOSE PREMIUM SOUND SYSTEM U68 - DRIVER INFO CENTER DISPLAY
1SF - LTZ PREFERRED EQUIPMENT GROUP 1 6DF - COMP FRT LH COMPUTER SEL SUSP
67I - MED OAK/OAK INTERIOR TRIM 672 - MED OAK/OAK ACCENTS
7DC - COMP FRT RH COMPUTER SEL SUSP 8DM - COMP RR LH COMPUTER SEL SUSP
86U - MAJESTIC RED METALLIC 9DM - COMP RR RH COMPUTER SEL SUSP
#33 ·
VIN 1GNDT13S922371393
VEHICLE BUILD
Merchandising Model : CT15506 -2002 TRAILBLAZER LS 4WD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : DVNZX4
Build Date : 01/16/2002 Build Plant : 12206
OPTION CODES
AM9 - SPLIT FOLDING REAR SEAT BACK AXP - MPV VIN IDENT POSITION
A50 - FRONT RECLINING BUCKET SEATS WITH FLOOR CONSOLE B30 - WHEELHOUSING & FLOOR CARPETING
B86 - MOLDING B/S COLOR B9C - GM PRODUCTION WEEK #03
CJ3 - CLIMATE CONTROL C1U - ENTERPRISE RENT A CAR
DAY - ASSEMBLY PLANT MORAINE, OHIO DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER
EVA - EVAP EMISSION REQUIREMENT FLT - FLEET PROCESSING OPTION
NC1 - CALIFORNIA EMISSIONS LEV N40 - POWER STEERING
N86 - FULL SIZE SPARE QC4 - 16" ALUMINUM WHEEL
QRE - P245/70R16 BW ALL SEASON TIRES R6F - IDENTIFY B CODE USERS
TB4 - LIFTGATE TFD - RETAIL AMENITY DELETE
VG8 - NOTICE TO BUYER LABEL VP6 - NOISE CONTROL
VQ2 - FLEET ORDERING & ASSIST. PROG. WITHOUT HOLDBACK VXS - COMPLETE VEHICLE LABEL
VX7 - FLT-LONG TERM DAILY RENTAL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
X88 - CHEVROLET CONVERSION YA7 - CALIF. ASSY. LINE EMISSION TEST
YD6 - BASE REAR SPRING YF5 - 50-STATE LOW EMISSION VEHICLE
1SB - LS PREFERRED EQUIPMENT GROUP 2 * POWER HEATED MIRRORS * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS W/DEEP TINT REAR * CRUISE CONTROL * BODY SIDE MOLDING 50U - SUMMIT WHITE
6SJ - COMP FRT LH COMPUTER SEL SUSP 7SJ - COMP FRT RH COMPUTER SEL SUSP
95D - MED PEWTER/DK PEWTER ACCENTS 95I - MED PEWTER/DK PEWTER INT TRIM
#32 ·
can you help me i know alot have allready asked
I have an 03 trailblazer ext and i bought it from the dealer as the secound owner and i have always wanted to see a print out of the fact options like you have been posting. I tried to find a site to do it becuase i hate to bother you but if you have a free minute could you please run this one for me Vin 1GNET16P836218039 I have always been curios why as an LT i have some options but not others i still like the trade of options for bigger motor it has the 5.3 Ltr and I tow a 21' atv trailer with no problems fully loaded. Also i was told by gm that some are wired for auto climate control and some are not well i have one of those controls coming by ebay (figured for 24 $ couldn't hurt to try pluging it in ) I am greatfull if you could do that for me when you have time thankyou for your time:thx
#34 ·
VIN 1GNET16P836218039
VEHICLE BUILD
Merchandising Model : CT15806 -2003 TRAILBLAZER EXT LT 4WD
Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : GCRW6X
Build Date : 03/21/2003 Build Plant : 13606
OPTION CODES
AM7 - FOLDING REAR SEAT AM9 - SPLIT FOLDING REAR SEAT BACK
AXP - MPV VIN IDENT POSITION B30 - WHEELHOUSING & FLOOR CARPETING
CJ3 - CLIMATE CONTROL C49 - ELECTRIC REAR WINDOW DEFOGGER
C7H - 6,400 LB GVW RATING DH2 - LIGHTED LH & RH VISOR MIRRORS
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER DK7 - OVERHEAD CONSOLE EQUIP ADJ
EVA - EVAP EMISSION REQUIREMENT FE9 - FEDERAL/NY/VT EMISSIONS
KG3 - 145 AMP ALTERNATOR K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
LM4 - VORTEC 5300 V-8 SFI ENGINE M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NF2 - FEDERAL EMISSION SYSTEM NP5 - LEATHER WRAPPED STEERING WHEEL
QTR - P245/65R17 FOUR ON/OFF ROAD WOL TIRES (REPLACES STD/OPT PKG TIRES) SLM - STOCK ORDERS
UA6 - THEFT DETERRENT ALARM SYSTEM UG1 - HOMELINK
UN0 - AM/FM STEREO W/CD PLAYER UPC - TRAVEL NOTE
UY7 - TRAILER WIRING HARNESS U73 - FIXED MAST ANTENNA
X88 - CHEVROLET CONVERSION YC5 - LT DECOR
ZY1 - SOLID PAINT 1SJ - LT EXT PREF EQUIPMENT GROUP LEATHER PLUS PACKAGE * PREMIUM LEATHER SEATING SURFACES ON 1ST AND 2ND ROW, 8 WAY POWER DRIVER AND PASSENGER SEATS WITH POWER LUMBAR SUPPORT * DRIVER CONVENIENCE PACKAGE: * DRIVER MESSAGE CENTER * AUTO CLIMATE CONTROL * REAR SEAT RADIO AND HVAC CONTROLS * REDUNDANT HVAC/AUDIO/DMC STEERING WHEEL CONTROLS * DRIVER'S SEAT MEMORY AND OSRV MIRROR * TURN SIGNAL OSRV MIRRORS * BODY COLOR HANDLES & GRILLE * VEHICLE COMMUNICATIONS PKG * ONSTAR COMMUNICATIONS SYS W/1 YR SAFE & SOUND PLAN * LIGHT SENSITIVE ISRV MIRROR
41U - ONYX BLACK 6WR - SUSPENSION
7WR - COMPONENT SUSPENSION 8HK - COMP RR RH COMPUTER SEL SUSP
9HH - COMP RR RH COMPUTER SEL SUSP 92H - DK PEWTER/DK PEWTER ACCENTS
#37 ·
VIN 1GNDS13S152117426
VEHICLE BUILD
Merchandising Model : CS15506 -2005 TRAILBLAZER LS 2WD
Gross Vehicle Weight Rating : 2520 kg (5557 lb) Order Number : HGSJCP
Build Date : 08/06/2004 Build Plant : 15206
OPTION CODES
A50 - FRONT RECLINING BUCKET SEATS WITH FLOOR CONSOLE B0L - GM PRODUCTION WEEK #29
B30 - CARPETING, COLOR-KEYED B32 - FLOOR MATS, FRONT AND REAR
B33 - REAR COLOR KEYED FLOOR MATS B84 - BODY SIDE MOLDINGS
C4D - GVW RATING - 5550 LBS C49 - REAR WINDOW DEFOGGER
KG4 - GENERATOR 150 AMP K18 - ELECTRIC AIR INJECTION SYSTEM
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL NT7 - EMISSION SYS FED - TIER 2
NZ3 - FULL SIZE SPARE N40 - POWER STEERING
PCK - ONSTAR PLUS PACKAGE * ONSTAR SYSTEM-INCLUDES 1 YEAR SAFE & SOUND * CRUISE CONTROL QC3 - ALUMINUM WHEELS
QRE - P245/70R16 FOUR ALL SEASON BLACKWALL TIRES R6B - PROC CODE, ONSTAR NOT FORCED
R6F - IDENTIFY B CODE USERS R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND UY7 - TRAILER WIRING HARNESS
U73 - FIXED MAST ANTENNA VP6 - NOISE CONTROL
VQ2 - FLEET ORDERING AND ASSISTANCE VXS - COMPLETE VEHICLE LABEL
VX7 - LONG TERM DAILY RENTAL PROGRAM V1K - LUGGAGE RACK CROSS-BARS
ZY1 - SOLID PAINT 1SB - LS PREFERRED EQUIPMENT GROUP 2 * POWER MIRRORS, HEATED * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS * BODY SIDE MOLDING * LUGGAGE RACK CROSS BARS * TRAILER WIRING CONNECTOR * REMOTE KEYLESS ENTRY * THEFT DETERRENT SYSTEM
1SZ - PREFERRED EQUIPMENT SAVINGS 28H - LIGHT GRAY
28I - INT TRIM LT GRAY/DK GRAY 6HN - SPRING
67U - SILVERSTONE METALLIC 7HM - FRONT SPRING
8EW - SUSPENSION 9EU - COMP RR RH COMPUTER SEL SUSP
#38 ·
Hey Mark, very cool of you to do this for those who have requested the info. Thank you for your time. When you have time I'd appreciate it if you would run mine - although, since my truck is badged as an Ascender and not as one of the American builds, I'm not sure it will be in the database.
4NUES16S332101271
Thanks in advance!
Regards,
Coach
#39 ·
VIN 4NUES16S332101271
VEHICLE BUILD
Merchandising Model : JS15806 -2003 ASCENDER 2WD
Gross Vehicle Weight Rating : 2815 kg (6207 lb) Order Number : S01712
Build Date : 11/21/2002 Build Plant : 43206
OPTION CODES
AJ1 - DEEP TINTED GLASS AJ7 - SIDE IMPACT AIR BAGS
AM7 - FOLDING REAR SEAT AM9 - REAR SPLIT FOLDING SEAT
AR9 - SEAT FRONT W/6W PWR DRIVER, PWR RECLINE, PWR 2 WAY LUMBAR & MANUAL PASS SEAT AU0 - REMOTE KEYLESS ENTRY
AXP - MPV VIN IDENT. BG2 - 3RD ROW FLOOR MATS
B30 - COLOR KEYED CARPETING B32 - FRONT COLOR KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS CJ3 - DUAL ZONE HEAT & AIR COND
C49 - REAR WINDOW DEFOGGER DAY - ASSEMBLY PLANT MORAINE, OHIO
DH2 - SUNSHADE VISOR, LH&RH SLIDING, W/ LIGHTED MIRRORS DK2 - MIRRORS OUTSIDE HEATED, REMOTE CONTROL, ELECTRIC, MIC BLACK
DK7 - CUSTOM INTERIOR ROOF CONSOLE EVA - EVAP EMISSION REQUIREMENT
FE9 - FEDERAL/NY/VT EMISSIONS GT4 - REAR AXLE - 3.73 RATIO
JF8 - 4-WHEEL POWER DISC BRAKES KG4 - 150 AMP GENERATOR
K34 - CRUISE CONTROL LL8 - VORTEC 4200 INLINE 6 CYL ENGINE
M30 - 4-SPD AUTO TRANS W/OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHL NRE - CATALYTIC CONVERTER
N40 - POWER STEERING N74 - ALUMINUM SPORT WHEEL
N79 - STEEL WHEEL FULL SIZE SPARE QTE - BF GOODRICH ON/OFF ROAD TIRES
Q4B - GVW RATING - 6200 LBS R7D - WARRANTY HOLDBACK
R9Z - POMS EXPEDITE-SOLD ORDERS SLM - STOCK ORDERS
TB4 - LIFTGATE/LIFTGLASS BODY T61 - DAYTIME RUNNING LAMPS
T96 - FRONT FOG LAMPS T98 - VIN IDENTIFICATION
UA6 - THEFT DETERRENT SYSTEM UG1 - UNIVERSAL GARAGE DOOR OPENER
UN0 - ETR AM/FM STEREO CASS W/THEFT LOCK, AUTO TONE CTRL, SEE/SCAN CLOCK UY7 - WIRING HARNESS
V73 - STATEMENT OF CERT U.S. YC3 - BASE INTERIOR
YD3 - BASE EQUIP FOR SCH GVW PLATE YD5 - FRONT SPRING BASE EQUIP
YD6 - REAR SPRING BASE EQUIP ZW7 - PREMIUM SMOOTH RIDE SUSPENSION
ZY7 - TWO TONE COLOR COMBINATION Z89 - MARKET BRAND ISUZU
39U - INDIGO BLUE MATALLIC 6SK - FRT LH SUSPENSION
7SK - SUSPENSION 76L - BRONZEMIST
8HT - SPRING 9HS - SPRING
95H - MEDIUM PEWTER 95I - MEDIUM PEWTER
