For Release: July 1, 2003
OLDSMOBILE BRAVADA | Specifications
Overview
Model: Oldsmobile Bravada
Body style / driveline: front-engine, 2- and 4-wheel-drive mid-size utility
EPA vehicle class: mid-size sport utilities
Manufacturing location: Moraine, Ohio
Key competitors: Mercury Mountaineer, Jeep Grand Cherokee Limited, Nissan Pathfinder, Ford Explorer Limited, Acura MDX
Engine
Type: Vortec 4200 4.2L I-6 (LL8)
Displacement (cu in / cc): 256 / 4195
Bore & stroke (in / mm): 3.66 x 4.01 / 93 x 102
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: DOHC, 4 valves per cylinder, variable valve timing-exhaust
Ignition system: coil-on-plug, dual platinum electronics
Fuel delivery: sequential fuel injection, electronic throttle control
Compression ratio: 10.1:1
Horsepower (hp / kw @ rpm): 275 / 201 @ 6000
Torque (lb.-ft. / Nm @ rpm): 275 / 372 @ 3600
Recommended fuel: unleaded regular
Maximum engine speed (rpm): 6300
Emissions controls: NLEV; 3-way catalytic converter, positive crankcase ventilation, evaporative collection system
Estimated fuel economy
(mpg city / hwy / combined): 15 / 21 / 18 all-wheel drive
Transmission
Type: Hydra-Matic 4L60-E 4-speed automatic transmission, rear-wheel-drive, electronically controlled automatic overdrive with torque converter clutch
Gear ratios 1):
First:
3.06
Second:
1.63
Third:
1.00
Fourth:
0.70
Reverse:
2.29
Final drive ratio: 3.73:1 standard; 4.10:1 trailer towing option
Chassis/Suspension
Front: double A-arm, 46-mm shocks, 46-mm stabilizer bar
Rear: 5-link solid axle, 46-mm shocks, 24-mm stabilizer bar
Traction control: SmartTrak (standard on AWD)
Steering type: rack-and-pinion (hydraulically assisted)
Steering ratio: 20.4:1
Turning circle, curb-to-curb
(ft / mm): 36.4 / 11
Brakes
Type: 4-wheel vented disc with front aluminum dual piston calipers,
standard 4-wheel ABS
Rotor diameter x thickness
(in / mm): front: 12 x 1.14 / 305 x 29;
rear: 12.8 x 0.78 / 325 x 20
Total swept area
(sq in / sq cm): front: 127 / 217;
rear: 1340 / 1397
Wheels/Tires
Wheel size & type: 6-lug nut, cast aluminum 17-inch standard
Tires: std: P245/65R17; opt: P255/60R17(AWD)
Dimensions
Exterior
Wheelbase (in / mm): 113 / 2869
Overall length (in / mm): 191.8 / 4871
Overall width (in / mm): 75.4 / 1894
Overall height (in / mm): 74.5 / 1826
Track (in / mm): front: 63.1 / 1603
rear: 62.1 / 1577
Minimum ground clearance
(in / mm): 8 / 203
Ground to top of rear load floor
(in / mm): 32.1 / 817
Step-in height (in / mm): 18.2 / 462
Approach angle: 29º
Breakover angle: 18º
Departure angle: 23º
Curb weight (lb / kg): 2WD: 4442 / 2015; 4WD: 4628 / 2099
Weight distribution (% front / rear): 2WD: 53 / 47; 4WD: 55 / 45
Interior
Seating capacity (front / rear): 2 / 3
Head room (in / mm): front: 40.2 / 1021; rear: 39.6 / 1006
Leg room (in / mm): front: 43.1 / 1133; rear: 37.1 / 942
Shoulder room (in / mm): front: 58.5 / 1485; rear: 58.5 / 1485
Hip room (in / mm): front: 55.5 / 1410; rear: 58.1 / 1476
Capacities
GVWR, standard (lb / kg): 2WD: 5550 / 2517; 4WD: 5750 / 2608
Payload, base (lb / kg): 2WD: 1107 / 502; 4WD: 1122 / 509
Cargo volume (cu ft / L): interior: 80.1 / 2268
rear seat up: 39.8 / 1127; folded: 80.1 / 2268
Trailer towing maximum (lb / kg): 2WD: 6200 / 2812; 4WD: 6100 / 2766
Maximum tongue weight (lb / kg): 400 / 181
Fuel tank (gal / L): 18.7 / 71.5
Engine oil (qt / L): 7 / 6.6
Cooling system (qt / L): 13.9 / 13.1
