Buick Rainier
TrailVoy.com is the premier Chevy TrailBlazer and GMC Envoy Forum on the internet. Registered Users do not see the above ads.
Old 11-06-2008, 11:03 AM
tomas216's Avatar
tomas216 tomas216 is offline
2003 GMC Envoy SLT
Sandalwood Metallic 4.2L I6 4X4
gmos-04 gain control
gmos-04 problems. ive got a pioneer avic d3 headunit in my envoy. the gmos-04 gain control i cannot get right. if i turn it up high, i get that annoying alternator whine, if i turn it down low, the sound cuts on and off from the front speakers (lack of voltage?) when i turn up the volume on the deck. cant get it right, and when i get it close, it changes after a week or two. is there another adapter out there that works better? ive got an 03 envoy with the bose system.
another thing that bothers me is when i shut off the vehicle in the middle of a song on my ipod, the song starts over when i restart the vehicle. is that caused by the gmos04 or my steering wheel control interface?
Old 11-06-2008, 08:03 PM
chevtrlblzr's Avatar
chevtrlblzr chevtrlblzr is offline
Senior Member
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
I'm not sure what the problem might be. That's the adapter I'm using - I set it up and it stayed OK.
I don't remember if I could get to the level adjustment screw while the radio was on or if I had to try it - readjust - try it - readjust,...
But you want to have the radio at 3/4 or a little above and adjust the screw to proper sound level for that volume setting.
Also check that the RCA's from the deck are hooked to it correctly - I don't think they had them marked very clearly. Not sure that that would cause the problem you're having but ...???
Maybe the GMOS-04 itself is faulty - if you got it locally, maybe they'll let you try a new one and if it works return the old one??
Old 09-05-2009, 11:08 PM
gpski's Avatar
gpski gpski is offline
2008 Chevy TrailBlazer LT
Monterey Maroon Metallic 4.2L I6 4X4
add ground line to hu to body of truck
add ground loop isloator
ad just gmos 4 ahhhhhh so much better
Old 11-03-2009, 12:40 AM
tomas216's Avatar
2003 GMC Envoy SLT
ground loop isolator might work, but ive tried grounding to a couple different parts of the chassis with even worse whine. ive definately got something wrong with the gmos-04, im gonna order a new one and see if it fixes it. it might be a loose wire in the harness that plugs in to it as well.
Old 11-03-2009, 09:53 PM
Senior Member
Black 4.2L I6 4X4
Oh crap, you've been dealing with that for a year?
I think I remember something about Pioneers whining being fixed by grounding the rca's.
AKA Nelson
You may not post new threads
You may not post replies
Advertising Information
