Holy crap! It's a biggie!
VIN : 1GHDT13S722236495
VEHICLE INFORMATION
Merchandising Model : HT15506 -2002 BRAVADA AWD Warranty Start Date : 11/03/2003
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : YARK OLDSMOBILE
6019 W CENTRAL AVE
TOLEDO , OH 43615-1803
(419) 841-7771
Selling Source : 15 - OLDSMOBILE
Site Code : 07651
Business Associate Code : 117201
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 03012 TRANSMISSION SHIFT LOCK AND IGNITION KEY REMOVAL OVERRIDE COMPLIANCE N/A Closed
RC 03039 CHILD RESTRAINT ANCHORAGE SYSTEM INFORMATION N/A Closed
RC 04005 WINDSHIELD WIPER MOTOR FAILURE N/A Closed
YT 04032 SOFTWARE UPGRADE MAY BE NECESSARY. REFERENCE BULLETIN 01-06-04-052. N/A Closed
RC 04037 FRONT SEAT BELT RETRACTOR NONCOMPLIANCE N/A Closed
RC 04048 ELECTRONICALLY CONTROLLED AIR SUSPENSION/POWERTRAIN CONTROL MODULE N/A Closed
RC 04087 TAIL LAMPS/STOP LAMPS N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:
www.onstarenrollment.com or (888)ONSTAR1 (888)667-8271
XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or:
www.gm.xmradio.com or (800)556-3600
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 11/03/2003 0 miles 11/03/2006 36000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 11/03/2003 0 miles 11/03/2009 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/03/2003 0 miles 11/03/2011 80000 miles
36/36000 FEDERAL EMISSION 11/03/2003 0 miles 11/03/2006 36000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/09/2005 459749 # J5645 - INJECTOR, FUEL - DIAGNOSIS 33203 miles
09/09/2005 459749 # E2147 - LINK OR BUSHINGS, FRONT STABILIZER SHAFT AT CONTROL ARM - 33203 miles
09/09/2005 459749 # B4160 - MOTOR, ELECTRIC REMOTE CONTROL MIRROR - RIGHT - REPLACE 33203 miles
09/09/2005 459749 # B4161 - MOTOR, ELECTRIC REMOTE CONTROL MIRROR - LEFT - REPLACE 33203 miles
09/09/2005 459749 # N8520 - MODULE AND/OR SWITCH, DOOR -- REPROGRAM WITH SPS 33203 miles
08/17/2005 684073 # Z2084 - ROADSIDE SERVICE (FLAT TIRE) 32000 miles
08/03/2005 459103 # N8520 - MODULE AND/OR SWITCH, DOOR -- REPROGRAM WITH SPS 30654 miles
06/09/2005 128688 # J3390 - CLUTCH ASSEMBLY, FAN - REPLACE 27617 miles
12/22/2004 122741 # Y0008 - OBD II SOFTWARE UPGRADE, REPROGRAM PCM SB#01-06-04-052 21787 miles
12/22/2004 122741 # V1265 - 04087 - INSPECT AND REPLACE ONE OR BOTH TAIL LAMP CIRCUIT 21787 miles
11/16/2004 121464 # E4177 - LINK ASSEMBLY, REAR STABILIZER SHAFT - BOTH - REPLACE 21213 miles
09/01/2004 118604 # K4400 - TRANSFER CASE ASSEMBLY - R&R 17797 miles
09/01/2004 118604 # V1210 - 04048 - INSTALL WIRE HARNESS 17797 miles
09/01/2004 118604 # Z7903 - 3-DAY COURTESY TRANSPORTATION 17797 miles
08/17/2004 118000 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 17321 miles
07/29/2004 117359 # V1167 - 04037 - INSPECT SEAT BELT RETRACTORS, NO FUTHER ACTION REQ 16311 miles
07/29/2004 117359 # V1115 - 04005 - INSPECT WSW MODULE AND INSTALL SEAL ASSEMBLY 16311 miles
05/17/2004 114653 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - R&R OR REPLACE 12180 miles
05/17/2004 114653 # H0137 - ROTOR ASSEMBLY - REAR - BOTH - R&R OR REPLACE 12180 miles
03/05/2004 112064 # N8521 - TRANSFER CASE MODULE REPROGRAMMING WITH SPS 10022 miles
02/19/2004 111505 # K4126 - ACTUATOR ASSEMBLY, TRANSFER CASE - REPLACE 9211 miles
02/06/2004 111052 # N1720 - FUSE - REPLACE 8739 miles
11/19/2003 504214 # V0994 - 03012-INSTALL PLUG AND REMOVE OVERRIDE LEVER 6387 miles
11/19/2003 504214 # C2686 - LAMP ASSEMBLY, INTERIOR AND/OR REAR COMPARTMENT - REPLACE 6387 miles
11/19/2003 504214 # R5111 - ANTENNA AND/OR MOUNT ASSEMBLY (CELLULAR) - REPLACE 6387 miles
03/26/2002 432538 # K4124 - SENSOR ASSEMBLY, TRANSFER CASE RANGE SELECTOR - REPLACE 3213 miles
10/05/2001 411595 # J5650 - INJECTOR, FUEL - REPLACE 17 miles
09/04/2001 407508 # Z6999 - PDI RELATED FLUID ADDS 3 miles
08/24/2001 A36495 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
