2005 Trailblazer Transmission fluid change question - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 04-20-2017, 05:04 PM
BCTB05 BCTB05 is offline
2005 Chevy TrailBlazer LS
Hi All, I have a 2005 4WD Trailblazer with the I-6 4200 engine and I want to change the transmission fluid in it. It's not super dirty and the trans shifts fine, but with 140,000 miles on it, it's time to change the fluids out since I don't know the service history.
Main question is if you can drop the transmission pan without removing the bracket on the side of the transmission case for the shift cable? I can get to the rear bolt on the bracket and it moves a little bit until it hits the driveshaft for the front axle. It looks like I can get the pan bolts out without any problems, but will that bracket cause problems removing and replacing the pan. The manual I have says to remove the bracket, but it's easier said than done, so has anyone done this without removing the bracket?
Also, when it comes to the transmission fluid, the owner's manual calls for Dextron III while the parts store and the filter manufactures call for Dextron VI. I know you can mix the 2 types, but what are your opinions on the fluid?
I wasn't going to do a flush, just drop the pan and change the filter this time around.
Thanks in advance!
Old 04-20-2017, 09:23 PM
gatorglenn gatorglenn is offline
2003 GMC Envoy SLT XL
Pewter Metallic 4.2L I6 4X4
I have a 03 so don't know if there is any change in year. But I can get the pan off without moving the linkage bracket. I think why the book said s to is to make it easier to put back with the gasket. For fluids dextron what ever is over lll. When they make a new one I always move up. As long as it's covered at least the lll
Old 04-22-2017, 11:26 PM
Thanks gatorglenn
Thanks for the reply! I figured that the pan would come off without taking the linkage bracket off. I was more concerned if it would be a problem to get the pan back on without causing issues with the filter if you had to jockey the pan around to get it back on with the bracket in place. But it sounds like you've had no problems changing yours out. Thanks again!
Old 04-23-2017, 12:00 AM
AWD V8's Avatar
AWD V8 AWD V8 is offline
Senior Member
2003 GMC Envoy SLT
Indigo Blue Metallic 5.3L V8 AWD
Just be careful about "jockeying" the pan around. If you have to force it, it is possible to break one of the plastic shift solenoids. Don't ask how I know that.
I was planning on procrastinating today but I think I'll do that tomorrow.
