04 trailblazer LS question - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-08 SS General Tech Q&A > General
Old 04-16-2017, 04:18 PM
mizzharley mizzharley is offline
Silver Mist Metallic 4.2L I6 2WD
Hi everyone, I have 04 trailblazer. When I am at a light or just idle with the AC on it almost cuts off on me. The dash lights come on and all. Also when im idle it sounds likes it running kind of rough. Thank you
Old 04-16-2017, 05:37 PM
EnvoyBoy2004 EnvoyBoy2004 is online now
Time to clean the throttle body. Do a search on throttle body cleaning or check on Youtube.
Old 04-17-2017, 02:46 PM
Thank you will have it done
Old 04-18-2017, 03:25 PM
mbeverly mbeverly is offline
Light Pewter Metallic 4.2L I6 4X4
rough idle
car in park , a c on , car stalls out , throttle body was cleaned ?:
Old 04-20-2017, 10:17 AM
Question
what if it keeps a rough idle when stopped once I clean throttle body ? Im taking it tomorrow to have it cleaned. What else could it be then ?
Old 04-29-2017, 07:45 PM
DaytonGuy's Avatar
DaytonGuy DaytonGuy is offline
2006 Chevy TrailBlazer LS EXT
Silverstone Metallic 4.2L I6 2WD
My 06 has a problem with water leaking into the #1 and #2 spark plug hole. Every once in a while I have to remove the coil and the plug, clean the coil boot and put it all back together. Only takes about 20 minutes, but it smooths out the idle everytime. Not saying that's your problem, but that's a problem I have.
Old 05-02-2017, 08:30 AM
Throttle body cleaned
Hi Good morning finally got throttle body clean still has a rough like sound when idle. Also had to get fan clutch replaced now it sounds like a lot of wind is that normal ? thx
