VIN : 1GNDT13S022383514
VEHICLE INFORMATION
Merchandising Model : CT15506 -2002 TRAILBLAZER LTZ 4WD Warranty Start Date : 03/26/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : CENTURY III CHEVROLET, INC.
2430 LEBANON CHURCH RD
WEST MIFFLIN , PA 15122-2555
(412) 466-9210
Selling Source : 13 - CHEVROLET
Site Code : 13143
Business Associate Code : 113496
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 02016 FUEL FILTER FITTING DISCONNECT N/A Closed
RC 03012 TRANSMISSION SHIFT LOCK AND IGNITION KEY REMOVAL OVERRIDE COMPLIANCE N/A Closed
RC 03013 INSTRUMENT PANEL CLUSTER GAUGES INOPERATIVE N/A Closed
RC 04005 WINDSHIELD WIPER MOTOR FAILURE N/A Closed
RC 04037 FRONT SEAT BELT RETRACTOR NONCOMPLIANCE N/A Closed
RC 04087 TAIL LAMPS/STOP LAMPS N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or:
www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 03/26/2002 0 miles 03/26/2005 36000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 03/26/2002 0 miles 03/26/2008 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/26/2002 0 miles 03/26/2010 80000 miles
36/36000 FEDERAL EMISSION 03/26/2002 0 miles 03/26/2005 36000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
02/24/2005 005756 # V1265 - 04087 - INSPECT AND REPLACE ONE OR BOTH TAIL LAMP CIRCUIT 58928 miles
02/24/2005 005756 # V1167 - 04037 - INSPECT SEAT BELT RETRACTORS, NO FUTHER ACTION REQ 58928 miles
02/24/2005 005756 # V1115 - 04005 - INSPECT WSW MODULE AND INSTALL SEAL ASSEMBLY 58928 miles
02/24/2005 005756 # V0994 - 03012-INSTALL PLUG AND REMOVE OVERRIDE LEVER 58928 miles
08/11/2003 620241 # Z8016 - ROADSIDE GONE ON ARRIVAL 1 miles
06/05/2003 079249 # Z7901 - 1-DAY COURTESY TRANSPORTATION 21350 miles
06/05/2003 079249 # N2580 - SWITCH - TRANSFER CASE INDICATOR LAMP - REPLACE 21350 miles
06/05/2003 079249 # V0995 - 03013-REPROGRAM IP CLUSTER 21350 miles
06/05/2003 079249 # N6612 - WIRING AND/OR CONNECTOR - EXTERIOR LIGHTING - REPAIR OR RE 21350 miles
02/26/2003 073820 # N0528 - BULBS, LAMP - EXTERIOR - REPLACE 15760 miles
12/12/2002 282761 # K4122 - MODULE, TRANSFER CASE SHIFT - REPLACE 12838 miles
12/12/2002 282761 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 12838 miles
12/10/2002 282593 # N6614 - WIRING AND/OR CONNECTOR - INTERIOR/REAR COMPARTMENT LIGHTI 12806 miles
12/10/2002 282593 # N8521 - TRANSFER CASE MODULE REPROGRAMMING WITH SPS 12806 miles
11/26/2002 281961 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 12548 miles
10/17/2002 368151 # V0852 - INSTALL NEW FUEL FILTER QUICK CONNECT RETAINERS 10361 miles
07/01/2002 061224 # B4156 - OUTSIDE REARVIEW MIRROR REPLACEMENT - LEFT SIDE 5307 miles
02/11/2002 171672 # Z6999 - PDI RELATED FLUID ADDS 3 miles
02/05/2002 A83514 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
CHECK HISTORY INFORMATION
Vehicle Has No Associated Check History Information.
VIN 1GNDT13S022383514
VEHICLE BUILD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : DWBCRN
Build Date : 02/05/2002 Build Plant : 12206
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AAB - MEMORY DRIVER CONVENIENCE PKG AJ1 - DEEP TINTED GLASS
AJ7 - DR/PASS FRT & SIDE AIRBAGS AM9 - SPLIT FOLDING REAR SEAT BACK
AP9 - CARGO CONVENIENCE NET AR9 - FRT BUCKET SEAT, DELUXE WITH LEATHER SEATING SURFACES
AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER AXP - MPV VIN IDENT POSITION
BVE - SIDE RUNNINGBOARD STEPS B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS
CE1 - RAIN SENSING WIPERS CF5 - ELECTRIC SUNROOF
CJ2 - AUTOMATIC CLIMATE CONTROL C49 - ELECTRIC REAR WINDOW DEFOGGER
C5N - GVW RATING - 5750 LBS DAY - ASSEMBLY PLANT MORAINE, OHIO
DD7 - ISRV MIRROR W/COMPASS DK7 - OVERHEAD CONSOLE EQUIP ADJ (DELETE TRAVEL NOTE)
D25 - MIRROR O/S LH & RH, REMOTE CTL, ELECTRIC, HEATED W/TURN SIG IND EVA - EVAP EMISSION REQUIREMENT
FE9 - 50-STATE LOW EMISSION VEHICLE
GT4 - REAR AXLE - 3.73 RATIO
G80 - LOCKING DIFFERENTIAL-REAR AXLE JF8 - BRAKE VAC POWER, 4 WHL DISC
KA1 - HEATED FRONT SEATS KG4 - GENERATOR 150 AMP
K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED LL8 - VORTEC 4200 SFI I6
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
N40 - POWER STEERING N74 - 17" ALUMINUM SPORT WHEEL
N79 - FULL SIZE SPARE QTR - P245/65R17 ALL-SEASON WOL ON-/ OFF ROAD TIRES
RYJ - RETRACTABLE CARGO AREA COVER SLM - STOCK ORDERS
STW - LEATHER WRAPPED STEERING WHEEL W/CONTROLS TB4 - LIFTGATE
T61 - DAYTIME RUNNING LIGHTS T96 - FRONT FOG LAMPS
T98 - STAMPING VEHICLE IDENT NUMBER UA6 - THEFT DETERRENT ALARM SYSTEM
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN UG1 - HOMELINK
UK6 - RADIO CONTROLS RR ST & EARPHONE UPC - TRAVEL NOTE
UP0 - AM/FM STEREO W/CASS & CD PLAYER U68 - DRIVER INFO CENTER DISPLAY
U73 - FIXED MAST ANTENNA VXS - COMPLETE VEHICLE LABEL
V40 - POWER PASSENGER SEAT PROVISIONS V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
X88 - CHEVROLET CONVERSION YC6 - LTZ DECOR
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING ZQ3 - DRIVER CONVENIENCE PACKAGE: DRVR MESSAGE CNTR, AUTO CLIMATE CONTROL, RR SEAT RADIO AND HVAC CTRLS. LEATHER STRG WHL W/CONTL
ZW7 - PREMIUM RIDE SUSPENSION ZY1 - SOLID EXTERIOR APPEARANCE
1SF - LTZ PREFERRED EQUIPMENT GROUP 1 11U - LT PEWTER METALLIC
6SK - COMP FRT LH COMPUTER SEL SUSP 7SJ - COMP FRT RH COMPUTER SEL SUSP
8EZ - COMP RR LH COMPUTER SEL SUSP 9EX - COMP RR RH COMPUTER SEL SUSP
92I - DK PEWTER/DK PEWTER INT TRIM 922 - DK PEWTER/DK PEWTER ACCENTS
