4.2L slow cranking - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-01-2013, 09:35 PM
cthudak cthudak is offline
2006 Chevy TrailBlazer LS EXT
Pewter Metallic 4.2L I6 4X4
4.2L slow cranking
Thanks for the great forum and priceless info. I have searched and read most of the threads related to slow cranking. My 2006 TB EXT LS is cranking slow lately. I have a 75 month napa battery that's 3 years old. The starter is original w/ 98k on it. I removed and cleaned the pos and neg connections on the battery. The ground battery cable to the body is .1 ohms. The battery reads 12.6 volts, and drops to 10 volts during cranking. My question is, is there a known problem with Chevy starters on the 4.2? My next step is to get the battery load tested I guess.
Any thoughts or suggestions are greatly appreciated.
Old 01-02-2013, 07:56 PM
vipergg's Avatar
vipergg vipergg is offline
Senior Member
2008 Isuzu Ascender
Midnight Metallic 4.2L I6 2WD
crank
Starter is one of the few things I havent heard of people having a lot of issues with . I would get the battery load tested specially if its suddenly gotten colder where you are. How many CCA's is it rated for ?
Old 01-15-2013, 05:42 PM
Problem resolved. Starter finally gave out. Load tested battery - checked good. Replaced starter - all is well.
Thanks for all the help
Old 01-15-2013, 11:19 PM
blown4pt3 blown4pt3 is offline
2003 Chevy TrailBlazer LS
Onyx Black 4.2L I6 4X4
Sorry to respond after you fixed it, but the slow cranking is exactly what mine did before the starter died completely. It was sort of funny how it went though, it was fine, then all of then overnight it was slow for a week or so, and just before I ordered a new one, I got stranded. No hard starts/no starts, just seemed to take longer than normal to turn over. Someone who didnt drive the blazer everyday most likely wouldn't know it. Fortunately it wasnt far from the house. But anyone with a slow crank and decent battery needs to swap the starter. I had about 140k on mine when it died. Or at least pull the starter and get it tested. Mine didnt want to spin even on a test stand. Just plain dead. Solenoid was good and would "click".
Old 01-16-2013, 03:51 PM
Your symptoms were exactly like mine, although my original starter only made it 90k....but wife puts alot of cycles on it every day
Old 01-21-2013, 03:33 PM
AJ19781222 AJ19781222 is offline
2005 Chevy TrailBlazer LS
Monterey Maroon Metallic 4.2L I6 AWD
Glad you got it fixed, Just solved same problem with a friend had 167K on orig starter
Old 03-03-2013, 11:40 PM
Dollarbilly's Avatar
Dollarbilly Dollarbilly is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Noisy starting when very cold
My 04 LS 4.2 makes a noise when starting in cold weather (below 40F or so). It sounds like the starter isn't engaging completely. When the weather is warmer or the engine is warmed up it starts fine. I notice when I first turn the key on (before cranking) on a cold morning the volts are around 10.5 which I thought was kinda low. And after starting it runs at 14 plus for a while which makes me suspect the battery since the starter noise only happens when it's cold outside after the truck has been sitting overnight. I believe the battery is fairly new but haven't checked it since I purchased the truck used. Thoughts, please?
You may not post new threads
You may not post replies
