Transmission Question Please help!!! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-15-2013, 02:50 PM
xuscxtrojanx xuscxtrojanx is offline
2002 Chevy TrailBlazer LT
Hi All,
This is my first post, although I have read other threads that have been very useful throughout the years in DIY maintenance, etc.
Today I was driving the car to work and all of the sudden I had a lack of power. The engine would go up in RPMs but the vehicle didn't want to move much. I was able to drive into a parking lot nearby. Once I took a lap around the parking lot all seemed fine until the next light where the problem persisted.
Now I am able to start the vehicle all sounds fine, and I can move the shifter, but it doesn't seem to be in gear as there is no power. I am able to put it into neutral and roll it. My vehicle is 2WD.
I see no leaking transmission fluid. Fluid is clean and reddish pink, there is no burning smell. Fluid level is good.
Does not move in reverse, shifts into all gears. I checked the linkage and it moves when the car is shifted in the respective gears. No check engine lights illuminated.
Is the transmission done? I am willing to check anything or try anything that you think might help.
Thank you in advance for your time and assistance!
Old 01-15-2013, 03:01 PM
freddyboy61's Avatar
freddyboy61 freddyboy61 is offline
2004 GMC Envoy SLE XL
Summit White 4.2L I6 4X4
You didn't say how reverse was? How many miles on the truck? Is the Check Engine light on?
Sounds like you need a tranny shop, A/Ts are usually DIY projects.
Freddyboy61
Old 01-15-2013, 08:13 PM
CarbonJoe CarbonJoe is offline
2003 GMC Envoy SLT XL
Pewter Metallic 4.2L I6 AWD
No reverse is usually the sun shell. Not shifting in forward gears could be the solenoids, or controller. In any case, it sounds like a tranny rebuild is in your future. Make sure the place that rebuilds it uses an aftermarket sun shell, like the Beast from Monster Transmission.
Old 01-15-2013, 09:54 PM
How much should the total rebuild cost? Any recommendations on where I should take it. I am in Anaheim, CA.
Old 01-16-2013, 07:54 PM
My rebuild on a 4wd 4L60E was $1700, all inclusive. I had it done at a local place that's been around for 20+ years.
Old 01-17-2013, 02:20 PM
NoId's Avatar
NoId NoId is offline
2003 Chevy TrailBlazer LS
I have a 4x4 2003 lt. My trans full rebuild including the torque converter cost me 2500 from ammco. That included the tow to the shop.
You may not post new threads
You may not post replies
