Oil loss mystery? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 01-16-2013, 05:26 PM
Dafy46 Dafy46 is offline
2002 GMC Envoy SLT
Silver Mist Metallic 4.2L I6 4X4
Oil loss mystery?
Newbie here, first post. 2002 Envoy SLT 6 cyl auto Canadian car. Red engine light comes on and it is low oil problem. 1.5 qts and everything is fine for 6 weeks. dry oil pan right past the start of the transmission then some wetness. threw in some gunk and the small drip in the driveway stopped. no smoking either. any suggestions before I get the word from the dealer.
sorry I cant give you a mileage between red lites. car has 107K miles. I thought at first that the dealer forgot that it takes 7 qts and not 5 when the oil changed.
Old 01-16-2013, 09:31 PM
moostadon moostadon is offline
2005 Chevy TrailBlazer LT EXT
Magnetic Red Metallic 5.3L V8 4X4
the plant manager where i work has the same issue with his tb,he told me that gm used low tension oil rings to try to help out the fuel economy he said that he has been putting slick 50 in with his oil and the problem seems to have quit ,my 5.3 does the same as well i wonder if its carbon build up on the rings or if it because of the active fuel management system running on 4 cyls cruising i think the oil is quench cooling the rings making a carbon build up ,i was thinking bout putting a quart of trans fluid in the oil to clean things up
Old 01-16-2013, 09:49 PM
2002 GMC Envoy SLT
thxs for the tip, I'll make a note of the additive if nothing else comes up.
Dafy46
Old 01-17-2013, 07:14 AM
NJTB04 NJTB04 is offline
2004 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
I've read on here the 5.3's have an updated valve cover that corrects this.
Old 01-17-2013, 09:37 AM
2002 GMC Envoy SLT
Thks, I also read that prior to posting but I have a different engine and not
being a mechanic felt that they wouldn't be interchangeable parts from 8 to 6.
You may not post new threads
You may not post replies
