lifting - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 General Tech Q&A > Off-Road
Off-Road For suspension, wheel, and tire questions DIRECTLY related to Off-Roading.
Old 01-18-2013, 04:42 PM
bigblackbravado bigblackbravado is offline
2002 Olds Bravada
Black 4.2L I6 AWD
lifting
alright y'all here's my question...I bought a 2002 olds bravada, and i was wordering lift wise what i could do with it, my buddy is a mechanic and said that i could buy a lift for a trailblazer/envoy? is this true? i mean i know the older olds had the exact same parts as the blazer, and im just curious, i found a lift on BDS suspension for the trailblazer, would it work?
Old 01-26-2013, 01:54 PM
TheVoy's Avatar
TheVoy TheVoy is offline
2002 GMC Envoy SLT
Lifting your olds
Hello, I have a 2002 Envoy which I lifted myself. I have seen people with the Saab 9-7x using the same lift as a TB and Envoy so that shouldnt be a problem for your Olds.
There are not a whole lot of options as fas as lifting a GMT-360 platform. From the knowledge I have gained at this site, the most you can lift your suspension is about 3 inches. There are also body lifts available, but I have noticed that the frame sits a little lower then the body, and a body lift would only make that difference greater and more noticible.
I went with a 3 Inch front, 2 inch rear suspension spacer kit. AKA Lift kit, AKA Leveling Kit, or whatever you want to call it. It bolted directly to the top of the front strut assembly and seated on top of the spring in the rear. The difference is astonishing and with my new clearance, along with 1.5in wheel spacers, I was able to put 32.5in tires. It sits about 5 inches higher then it did stock, and it still rides great.
Others use rear springs out of a Z71 Tahoe instead of spacers, and from pics they also look awesome. I have even seen others using springs out of a Toyota pick up but unless your in the mood to fabricate them so they seat properly, I do not recomend it.
Hope this helps, PLEASE post pics regarding your progress, I dont thnk I have ever seen a lifted Oldsmobile brefore
Old 01-27-2013, 06:40 PM
darring70's Avatar
darring70 darring70 is offline
2002 Chevy TrailBlazer LS
Problem
I have a problem, I lifted my TB 3" and now I fell like I an in the air, stability is not good, I don't know if is anything that I can do about it.
Old 01-29-2013, 01:22 PM
TheVoy's Avatar
2002 GMC Envoy SLT
By lifting your TB 3 inches, you have messed with the center of gravity, so it is not going to handle the same. These are pretty top heavy vehicles to begin with. Why do you think sports cars sit soooo low?
The only way to increase stabibility is to get wheel spacers and wider tires to try to balance it out a little better by having a wider track. I have done both to my lifted Envoy, and its better, but its always gonna roll more then stock.
Old 01-29-2013, 01:52 PM
darring70's Avatar
Ok, I always had sports cars and I always lowered it, but is my first time with a truck and first time lifted, I drove it for two days already and ia not to bad after all, but I will do that buu spacers and wider tires, do you thing if I change the shocks will help to or it will be the same?
Old 01-29-2013, 02:02 PM
darring70's Avatar
Btw the shocks are stock and about 3 or 4 months old
Old 01-29-2013, 04:49 PM
TheVoy's Avatar
2002 GMC Envoy SLT
Technically, if you go with a heavy duty shock made for a truck you should have improved stability and cornering ability but I cant say that the difference will be that noticible, ONLY because your shocks are brand new. If they were worn out, different story.
You may not post new threads
You may not post replies
