| General If it doesn't fit in any other forum |
01-19-2013, 08:40 AM
2007 Chevy TrailBlazer LT Graystone Metallic 4.2L I6 4X4
2007 recall drivere window
Did anyone get their Tb driver window switch recall done.I am still waiting for the fix
01-21-2013, 12:41 PM
2006 Chevy TrailBlazer LT EXT Graystone Metallic 4.2L I6 4X4
we got the recall notice for our 06 about 6 months ago....have heard nothing from the stealership thats supposed to do it yet.
01-22-2013, 05:19 AM
Thanks to Evan a GM specialist ,GM called me and states the parts will be here in March Thanks Evan
01-22-2013, 08:51 AM
2009 Chevy Malibu Red Jewel Tintcoat Other 2WD
joe70ss,
You're welcome! I'm sorry for the wait.
Evan, GM Customer Service
 The new Owner's Center is here, visit my.gm.com!
01-22-2013, 12:45 PM
2005 GMC Envoy SLT white 4.2L I6 4X4
Hey all. I have the same problem with my 05 envoy. I found out that the recall is only on the 06-07 envoy. Does anyone know y this is or if a recall is to be made on the 05 as well being that it is the same problem. Is the recall for the door module itself? I called gm and they have no indication that there will b a recall placed on the 05. Please reply. N if any one knows a site I can purchase a used door module (used preferably, heard those don't have to be programmed in the meantime). Thanks all
01-22-2013, 01:31 PM
2009 Chrysler PT Cruiser Inferno Red Other 2WD
Only years recalled were the 06 and 07's like you said. That recall was offered a while back and since nothing else has been said I am guessing that no other years will be involved.
As far as used ones have you searched Ebay? I just did my own search and found many used ones for sale.
01-22-2013, 04:13 PM
Ok so I found if I search under switches not module I can find alot. Now my next question. Does anyone know definitive if I purchase a used master switch if it still has to go to the dealer to be programmed. Thanks again all to take the time to look at this
01-22-2013, 04:51 PM
A used one will not need programming. If you were replacing the lift gate module you would have to but not a used drivers door module.
01-22-2013, 04:57 PM
What is a lift gate? The window regularor. My mechanic said it should b ok if it is a switch from o4 or an early 05 my truck was manyfactured 12/04. So a used switch should not need it then right ?
01-22-2013, 05:12 PM
I am sorry. I didn't mean to confuse you. The lift gate module is in the rear lift gate. It controls the remote door locks and numerous other things in the lift gate. If it goes bad then even a used one has to be programmed to the options on the truck.
And again, a used door module will not need programming.
| Sponsored Links |
You may not post new threads
You may not post replies
