Growl whiny noise at cold start up - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 01-23-2013, 12:20 AM
Jewel red 5 Jewel red 5 is offline
2007 GMC Envoy Denali
Liquid Silver Metallic 5.3L V8 AWD
Hello I have a 07 envoy Denali 5.3 on start up t sounds like a loud whine or grinning noise or bering while standing in front of grill. It's not the fan noise engaging even when it heats up noise is still there but not as loud had the water pump done 2 times not the problem and the pulley replaced too along with the tension one also. At a loss thinking my be fan clutch going. Not sure need help maybe Bering but where, truck is in excellent shape garage kept 65000 miles please help you guys are so knowledgeable. Thanks.
Old 01-23-2013, 12:26 AM
rhill rhill is offline
2004 Chevy TrailBlazer LT
Summit White 5.3L V8 4X4
I had my air conditioner clutch/pulley bearings go out and make a bad noise. If you can get your AC to come on and it goes away, that would be the problem (although my AC compressor won't kick in when it is less than 60 degrees outside, or something like that so it might be difficult to troubleshoot in the winter depending on your location unless you can get it inside). My shop changed the bearing - they didn't have to change the compressor, so the system didn't have to be emptied and recharged .... much cheaper also.
Old 01-23-2013, 04:47 PM
Thanks I ran it today with no belt on comp still has noise still up in the air what it could be.
Old 04-19-2013, 10:21 PM
Solved
Had fan couch done by dealer under warranty sound is gone.
Old 04-21-2013, 10:05 AM
ramblinman ramblinman is offline
2003 Chevy TrailBlazer LT EXT
Black 5.3L V8 4X4
replaced fan clutch
Question: Does the computer have to be reset after replaceing fan clutch? Thanks
Old 04-24-2013, 01:42 AM
Not sure can ask dealer about it have to get the recall done next week. Will post new reply.
You may not post new threads
You may not post replies
