Windshield Washer Squirters - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-24-2013, 05:00 PM
Trailbuckeye's Avatar
Trailbuckeye Trailbuckeye is offline
2003 Chevy TrailBlazer LTZ
The problem I am having is that my front windshield washer squirters are only spraying out up about 2-3 inches on my windshield. Back has plenty of pressure. I have already checked for clogs in the nozzles themselves. Any ideas on what else it could be?
Thanks
Old 01-24-2013, 05:03 PM
Kspace5125's Avatar
Kspace5125 Kspace5125 is offline
2005 Chevy TrailBlazer LT
if you take out the pass head light you will see the washer resivor, you have 2 little pumps there. switch the lines and see if the front works as good as the back had. if it does then its your front washer pump. if not then you have a clog somewhere in the line from the resivor to the hood....
Old 01-24-2013, 05:42 PM
Loverotties Loverotties is online now
2002 Chevy TrailBlazer LTZ
Could be the filter screen could be clogged!
Old 01-25-2013, 07:02 PM
Ok so I went down and purchased a new pump and put that on. It did not change the intensity of the spray. I also took one of the air dusters and blew the air from the squirter back to the tank and I could hear bubbles so I am assuming that the lines are clear. Does anyone else have any ideas on what it could be? Any help would be appreciated. Not have windshield washer fluid during the winter SUCKS!!
Old 01-25-2013, 07:06 PM
I still think it's what I suggested!specially if you use the cheap blue crap!
Old 01-25-2013, 07:17 PM
Unfortunately I have been! No more. Where are the screens at and what's the best way to clean them?
Old 01-25-2013, 09:00 PM
It looks like the hose going from the pump to the squirters has a point where you can split it apart. Has anyone ever tried this? I though I could try to see if the pump is working at full power.
Old 01-26-2013, 12:41 PM
Problem fixed! After replacing the pump, taking out the reservoir and cleaning it, and cleaning out all of the lines it ended up being a partial clog in the nozzle. Should have looked there first. Loverotties was right. One positive from this, aside from it being fixed, is that I know how to disassemble and reassemble the entire windshield washer system.
Old 01-26-2013, 08:00 PM
craigwe craigwe is offline
2002 GMC Envoy SLE
Yup. You never know what you are going to find inside the nozzle. My 2002 nozzles are 2 pieces and I have taken them apart before. He tons of flow and pressure all the way up to the nozzle. Used a pick and took the nozzle halfes apart and found some little white stones or what ever it was. Like like silica sand granduals. Good fix!
Old 01-26-2013, 09:22 PM
That's wierd! That is exactly what was in my 03! No idea what it was.
You may not post new threads
You may not post replies
