Motorflush at 296K???? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-25-2013, 09:54 AM
j-floater2003 j-floater2003 is offline
2003 GMC Envoy SLT XL
I'm about to flush my engine on a 03 Envoy for the first time...........any precautions?? Should I even do it? Will it create any leaks afterwards?......Thanks!
Old 01-25-2013, 09:55 AM
Sorry it's 196K.
Old 01-25-2013, 11:30 AM
Machoman Machoman is offline
2005 GMC Envoy SLT
Black 4.2L I6 4X4
What are you going to flush?
Old 01-25-2013, 11:51 AM
The engine not the cooling system.
Old 01-25-2013, 12:51 PM
Ray Dockrey's Avatar
Ray Dockrey Ray Dockrey is offline
2009 Chrysler PT Cruiser
Inferno Red Other 2WD
Why are you flushing it?
Old 01-25-2013, 04:34 PM
Falcon LS Falcon LS is offline
2005 GMC Envoy SLE
Warm Grey Metallic 4.2L I6 2WD
As long as you do not use a kerosene based flush, I see no problem. On the contrary, it'll help clean up the piston ring packs.
If you haven't bought the flush yet, my suggestion would be Amsoil or Lubro Moly Pro-Line Engine Flush, which you can get on eBay. These are professional products that do the job well, without negatively affecting any seals or anything.
An alternative to clean up engine internals would be to use an oil like Pennzoil Ultra or Redline. Pennzoil Ultra has Gas to Liquid (GTL) base oils, which cleans like crazy. Redline is ester based, also renowned for its cleaning abilities.
I would also suggest running some Chevron Techron Fuel System Cleaner or 3M Max Strength Fuel System Cleaner in a full tank of gas. These have high doses of polyetheramine (or PEA), which is excellent at attacking and cleaning carbon and sulfur. GM sells Techron branded as a Genuine GM product at the dealer as well, but it's pricier.
Old 01-25-2013, 10:28 PM
I appreciate the feedback and replies from all of you. Thanks Falcon LS for the excellent post. I'm just trying to tune up my car.....just replaced the plugs, cleaned the throttle body, did the oil change and replaced the belt. Will also look up how to check my cat converter next since from the little reading I've done......it wont give a code if there is something wrong with it.
Old 01-26-2013, 07:54 PM
vipergg's Avatar
vipergg vipergg is offline
Senior Member
2008 Isuzu Ascender
Midnight Metallic 4.2L I6 2WD
flush
You might consider using something like "Auto-RX " which is a gentler way of cleaning the internals on the engine . Just google it , a lot people swear by it though I myself have never used it as I usually trade cars by about 130000 miles.
http://www.auto-rx.com/
Old 01-27-2013, 02:20 AM
2005 GMC Envoy SLE
I used to be a dealer for this stuff in the Middle East. It's a waste of time and money.
Old 01-27-2013, 03:17 PM
bkmain bkmain is offline
2006 Chevy TrailBlazer LT EXT
At 173k my engine sounds good, no leaks, normal to low oil consumption. I do not plan to flush my engine and I would not recommend anyone do this as a random preventative. The products mentioned are fine, but with not problem to tackle I don't see any reason to flush an engine. On the other hand I do not feel you would do any harm and if you want to do it go ahead. I'd be curious the results. Moving forward, top tier fuels, good synthetic oil changed timely, proper maintenance would do more to keeping a clean engine than most anything else.
You may not post new threads
You may not post replies
