Tires Cupping Need Opinions - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Tires
Tires Tires
Old 01-25-2013, 11:59 PM
B33p3r B33p3r is offline
2006 Chevy TrailBlazer LS
Graystone Metallic 4.2L I6 AWD
Hello everyone, TB '06. I'm having an ongoing issue with the front tires cupping on the insides. History: Purchased Destination A/t tires from Firestone, had alignment done upon installation. They do a front end check prior to alignment. Months later I notice the fronts cupping. Changed the struts. Still cupping. Bring it back and they check everything out again along with alignment. All in spec. Tech adjusted camber slightly out of spec to compensate for cupping. Still cupping. Bring it to a different, very reputable, mechanic. Called me back tonight and said there is nothing wrong with the front end at all.
I'll be getting an inspection done soon and know these tires will not pass due to cupping on the insides only. At least 1/2 tread on the rest of the tire if not more. I have no issues with getting new tires but don't want to put new tires on only to find out they are going to cup also. Could the problem be the tires themselves? Ideas?
Old 01-26-2013, 12:02 AM
huey1983 huey1983 is offline
2007 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
No i having the same problem with my 07 tb with toyo open country at checked almost every thing still having same problem
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 03-08-2013, 05:57 PM
robertgee robertgee is offline
Senior Member
Sandstone Metallic 4.2L I6 4X4
If you are actualy referring to tires "cupping", as in a scalloping fashion, the problem is either incorrect wheel balance OR a wheel weight has flown off, causing the wheel to be out of balance.
When a wheel is out of balance, it actualy "skips" on the road ..... making contact and breaking contact with road surface, causing the "cupping" that you see.
Old 04-03-2013, 09:44 PM
navion navion is offline
2003 Olds Bravada
Pewter Metallic 4.2L I6 AWD
Cupped Tires
I am having the same problem on a 2003 Bravada. The first set of OE tires lasted about 70,000 miles but had cupped. I replaced the original set with Goodyear Fortera's and after about 30,000 miles I ave the same cupping issue. Thought it might have been worn ball joints as OE are sealed and "maintenance free" as they say. So ball joints were replaced. Just wondering if I am missing something as well. Anyone found any other issues?
Old 08-18-2013, 10:53 AM
John H John H is offline
2002 Chevy TrailBlazer LT EXT
Black 4.2L I6 2WD
tire cupping inside tread
I have a 2002 tb ext lt I also have this tire issue I went to have an alignment done I was told by the tech the car is only slightly off on right caster this would not effect the tire wear I was told the lower ball joint is slightly worn and the lower control arm bushings are worn causing the irregular tire wear. There are 109K on car 1st set of tires lasted 60K current tires have 50k with plenty of tread on outside. Could this be the problem?
Old 08-18-2013, 10:08 PM
Iknowthefuture Iknowthefuture is offline
2000 Volkswagen Jetta
Black Other 2WD
Cupping is caused almost 100% of the time by blown shocks. balljoints will cause camber issues (tire edge wear) tie rods cause feathering (almost looks like an ocean waves if you draw them on a piece of paper)
Once tires are cupped, after replacing shocks, you need to replace tires because most cases the cupping won't wear down to make the tire smooth again
