17" wheels to 16" w/adapters. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Tires
Tires Tires
Old 02-14-2013, 12:10 PM
Old Blue Old Blue is offline
2002 Chevy TrailBlazer LTZ
I have a 02 tb ltz 4x4 non ext that came with 17" wheels. My question is if I get 1.5" wheel spacers can I run 16" wheels with spacers?
3.73 gear ratio, Aero chamber muffler, Resonator delete, 6k hid, Drilled slotted brakes, Marvel mystery oil, Diamond White
Old 02-14-2013, 10:49 PM
edwin edwin is offline
2003 Chevy TrailBlazer LS
17" wheels to 16"
shud be able to use 16" stock wheels without spacers. only LWB cant use 16" IIRC
Old 02-15-2013, 06:57 AM
So the stock 16x7 will fit no prob? What if I bought 16x8 aftermarket wheels, they would still the calipers from stock 17s?
Old 02-15-2013, 04:54 PM
Huh? I think what you are trying to say is will 16x8 fit answer is maybe depends on the back offset compared to original 16x7. You might need spacers for them to clear.
Old 02-15-2013, 07:02 PM
LMMJ's Avatar
LMMJ LMMJ is offline
2002 Chevy TrailBlazer LS
Indi-GO Blue Metallic 4.2L I6 4X4
You dont have the big brakes so you can use whatever GMT360 wheels you want
Luis
Old 02-16-2013, 08:43 AM
The plan is...
Markmc 2.5 lift
16x8 xd wheels 4.5 backspacing 0mm offset
265/75/16 treadwright guarddogs/wardens
Do I need spacers, I've done a search and found that stock 16x7 wheels with 1.5 wheel spacers comes out to around 4.5 backspacing. Also a good backspacing would be 5".
Old 03-03-2013, 11:20 PM
Dollarbilly's Avatar
Dollarbilly Dollarbilly is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
OK to swap 17" for 16" wheels/tires?
My 04 LT SWB has stock 245/65R17 wheels and tires. Have a buddy with an 06 LS SWB who has to get rid of his truck (pity). Question is, can I swap his 235/75R16 stock wheels and tires for mine without mods? Will it affect the speedo or computer? I imagine mine wouldn't corner as well with the smaller rims, however...comments, please?
Old 03-11-2013, 04:41 PM
CYRIL CYRIL is offline
2004 GMC Envoy SLT
Pewter Metallic 4.2L I6 4X4
sounds good
You may not post new threads
You may not post replies
