envoy abs issues - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 02-16-2013, 05:09 PM
doarider doarider is offline
envoy GMC Envoy SLT
Black 4.2L I6 4X4
envoy abs issues
ok im confused! abs and brake light came on the dash and abs is engageing at low speeds. scan showed right front speed sensor and a rear speed sensor. i replaced the front hub (bearing was going out so i rpleaced it all) and both sensors on the rear (figured if one was out the other wasnt far behind it) i also cleaned the ground under the drivers door just to be safe. i cleared the codes at my local parts store and without moving the vehicle both came right back as soon as i started the car. everything else (blower motor, speedo etc) are normal. any ideas?????? oh if i press very lightly on the pedal i hear a relay in the center console click and the lights go away when i release the pedeal they come back and the dic screen flashes service brake system. thanks in advance
Old 02-17-2013, 07:21 PM
envoy GMC Envoy SLT
Black 4.2L I6 4X4
anyone? i disconnected the battery cable for 30 min still have presets and the code still exsists where do i start? all sensors and bearing are new
