[SOLVED] not solved - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 02-26-2013, 05:04 PM
okanagan okanagan is offline
2002 GMC Envoy SLE
Summit White 4.2L I6 4X4
not solved
my 02 Envoy seems to surge into power when taking off from a stop. It seems almost like it is bogging and then surges in power. I have cleaned TB and replaced all plugs (GM iridium). She idles very nicely and smooth, at an idle can barely tell it is running!
Any idea why the surging or is this normal.
Thanks in advance.
Old 02-26-2013, 08:14 PM
byn2ools's Avatar
byn2ools byn2ools is offline
2002 Chevy TrailBlazer LS
I would install a fuel pressure gauge on it and drive it while watching the gauge and see if it drops pressure. If that is ok, Pull the front O2 out and install a back pressure gauge and watch the back pressure, Could be a converter starting to clog.
those would be the 2 things i would start out with checking
Old 03-13-2013, 07:47 PM
2002 GMC Envoy SLE
drive by wire?
can anyone advise as to repairing or replacing the electrical for the drive-by-wire on the throttlebody? I think that this may be the cause of my surging and I am hoping there is a fix besides replacing the throttle body.
thanks.
Old 03-13-2013, 10:41 PM
byn2ools's Avatar
If there was anything wrong with the throttle body, It would set a code right away and go into reduced power mode.
Has the front oxygen sensor been changed yet?
Old 03-14-2013, 03:17 AM
2002 GMC Envoy SLE
Thanks for the reply and suggestions!
I have not replaced the 02 and I do not have any codes at all. The Envoy idles and drives great, just when press down on pedal it sort of bogs and then surges with the power. Maybe I will try the 02
thanks again
Old 03-14-2013, 07:49 AM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
How old is your fuel filter?
Old 03-14-2013, 07:50 AM
How old is your fuel filter?Air filter?
Old 03-14-2013, 11:48 AM
2002 GMC Envoy SLE
Fuel filter is new, all new plugs, cleaned TB, air filter good, no codes and it idles and runs well.
Old 03-14-2013, 12:29 PM
What kind of plugs and gap.
Old 03-15-2013, 04:07 PM
2002 GMC Envoy SLE
plugs are GM Iridium with standard gap noted for the Envoy.
You may not post new threads
You may not post replies
