Transmission Stuck in 2nd gear - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-26-2013, 06:58 PM
prov1x prov1x is offline
2003 GMC Envoy SLE
Emerald Jewel Metallic 4.2L I6 4X4
Question Transmission Stuck in 2nd gear
Wife called me today and said her 03 GMC Envoy was shifting funny and would sometimes rev up real high. Went out to her work to check it and found that the fluid was low, went and bought 3 quarts and added one at a time with engine running checking fluids between each quart added and cycling the engine through the gears. After letting it warm up for a while I rechecked fluid and looks like I got it just barely over the mark for full. Went and drove it around and it would do fine in 1st and 2nd gear but when changing over to 3rd it would rev real high. I was able to get it home by just keeping it in 2nd gear.
ON the way home ,when trying to go into drive it seemed like it was stuck in 2nd gear. If manually changing it to 3rd it would just simply rev high and wouldn't go.
Looking for some opinions on thoughts if it is the whole transmission or possibly a fluid an filter change might resolve the issue. Doing some searching through the forums it looks like there is some talk on solenoids going bad also.
SO let me know what kind of issues others have ran into in a similar situation or point me in the way of some fixes.
Old 04-07-2013, 01:37 AM
chuy chuy is offline
2004 Chevy TrailBlazer LS
Imperial Blue Metallic 4.2L I6 AWD
did you ever find out what it was... i have the EXACT same thing.
Old 04-07-2013, 11:32 AM
RJenkins1581 RJenkins1581 is offline
2002 Chevy TrailBlazer LTZ
Pewter Metallic 4.2L I6 4X4
Time to change the 1-2 and 2-3 solenoids. You can get them from NAPA. Since your in there might as well change the 3-2 and the PWM and Force Motor, you can get a set on Ebay all AC DELCO for 88 bucks, that all the solenoid and even the wire harness. Just type in 4L60E Solenoids and there you go. Also change the filter and clean the magnet and pan. 2 hours tops if your on your back and have basic tools, 13mm and small flat head pocket screw driver or curved pic.
You may not post new threads
You may not post replies
