[SOLVED] Rear door won't open on my 2005 trailbrazer - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 07-05-2013, 09:36 PM
neo4192 neo4192 is offline
2005 Chevy TrailBlazer SS (LT)
Summit White 6.0L LS2 V8 4X4
The rear door on my 2005 trailbrazer won't open. Anyone have this issue?
Old 07-05-2013, 09:44 PM
szieziel szieziel is offline
2003 Chevy TrailBlazer LT EXT
do you mean the cargo hatch or a passenger door
Old 07-05-2013, 09:45 PM
door won't open
cargo hatch
Old 07-05-2013, 10:07 PM
could be a broken wire, a bad lift gate module, a bad lock actuator, or the door may not have completely latched due to an obstruction
does the rear wiper work?
does key fob work?
can you open the glass with all doors unlocked? how about locked?
the rear lift gate has a computer module in it that controls the functions of that door, it also acts as the receiver for the fob remotes
if it is the lock - you can manually unlock, on the inside of the hatch, near the center bottom, there should be a round plug/cap
pry it off to expose the locking rod and with a finger move it which ever way it will move - this does not require much force
then climb out and try the handle
Old 07-06-2013, 12:36 AM
Gevans17 Gevans17 is offline
2004 Chevy TrailBlazer LS
Dark Green Metallic 4.2L I6 2WD
hatch wont open
check for broken wires in the rubber boot at the top of the door
Old 07-03-2014, 07:56 AM
Cholo13 Cholo13 is offline
2005 Chevy TrailBlazer LS
Summit White 5.3L V8 4X4
Same problem
Mine was obstructed, by a floor mat, I got the mat out without any pieces of it missing but now my Hatch will not open for the life of me, wth do I do?
Old 07-03-2014, 08:08 AM
Help
My Hatch stupid opening when I closed it with my floor mat in the way, how can I fix it?
