Transfer Case Fluid Change (Automatic Transfer Case Only) - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-10-2006, 11:35 AM
Trefilov22 Trefilov22 is offline
2004 Chevy TrailBlazer LT
Monterey Maroon Metallic 4.2L I6 4X4
Thumbs down Transfer Case Fluid Change (Automatic Transfer Case Only)
According to mygmlink.com, this is the only service needed (besides oil and the basic stuff) at 50k miles?? Is that correct? If so, what exactly does that mean?
Trefilov22
Old 07-10-2006, 01:29 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
This means drain and refill your transfer case. There are seperate drain and fill plugs on it. Use only GM Auto-trak II oil. IIRC, it uses just over 1.5qts.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 07-10-2006, 05:21 PM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
Joel
Yep, I did mine at 49K when I changed every other fluid (except power steering which I need to do eventually).
Only use GM AutoTrak II fluid otherwise your TC will never work again, seriously. It is the only fluid that works in them. In mine I put about 1.8L in it, buy 2L of it from the dealership for like $10-12 per L.
Ohh, and make sure you have a 3/8" hex drive bit before attempting to remove the fill and drain plugs (remove fill first).
Old 01-10-2010, 05:37 PM
Ryan Ryan is offline
2005 Chevy TrailBlazer LT
anyone have pics of the locations of the plugs?
Old 01-10-2010, 06:01 PM
gmac310's Avatar
gmac310 gmac310 is offline
2002 GMC Envoy SLE
Cheer ya go; #13 is the fill, #15 is the drain:
Borrowed from one of Roadies posts, any distribution or replication of said material is a sign of admiration, all rights reserved.
Old 01-10-2010, 06:13 PM
where abouts does this sit in the truck? I thought I changed this yesterday but I accidentally changed the front diff fluid. opps. so I found that out and put the right fluid in the front diff but I couldn't find this? I think I was looking to far forward on the truck.
Old 01-10-2010, 07:13 PM
gmac310's Avatar
2002 GMC Envoy SLE
Should be right under your drivers seat.
Old 01-11-2010, 03:16 PM
Trailblazer88's Avatar
Trailblazer88 Trailblazer88 is offline
2006 GMC Envoy Denali
Summit White 5.3L V8 4X4
Just did mine this past weekend... What a pain in the a$$ to refill!!! Next will be the front and rear diff fluid... Are these easier to refill?
Old 01-11-2010, 04:24 PM
the roadie's Avatar
Except for the part about the locking hub, this is an overall diagram of a 4WD system. IMHO, nobody should own a vehicle without reading some elementary "How It Works" kind of sites or books.
http://auto.howstuffworks.com/
Similar Threads
Transfer case fluid level ironscott 4x4 Drivetrain 8 05-12-2014 12:55 PM
Tranny Fluid Change dpm6836 Transmission Mods 57 07-23-2011 10:58 AM
Transfer Case leak...and then not Bill2003 4x4 Drivetrain 22 10-06-2008 05:10 AM
Transfer case slipping into Neutral... chrome 4x4 Drivetrain 37 09-17-2008 09:00 AM
Change Transfer Case Fluid bbrase 4x4 Drivetrain 8 03-22-2006 01:09 PM
