Got code P0172 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-24-2006, 05:44 PM
Vince's Avatar
Vince Vince is offline
Senior Member
No longer own a TV. No longer own a TV. No longer own a TV.
No longer own a TV. Other 4X4
Got code P0172
On my way home form work today the service engine light came on. I stopped by Advance Auto and read the code and it is P0172 System Too Rich(Bank 1). My first thought ws bad 02 sensor. Then I rememberd that I had my battery disconnected for a while yesterday. Could this be why I got the code? I reset it and it didn't come back between Advance Auto and here(less than 5min drive). I did a search and didn't find much info about this code.
Old 07-24-2006, 11:18 PM
cliffwilson's Avatar
cliffwilson cliffwilson is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
DTC 0172 sets when the engine is in closed loop and the PCM detects an excessively rich fuel condition. While the O2 sensor, EVAP system and the fuel injectors should be tested, there are a few basics to immediately consider. First, contaminated fuel (water or alcohol) can be the culprit. It plays havoc with fuel trim. Second, obstructions in the air intake system should be checked. The air intake ducts and the throttle body should be examined for any blocked or dirty conditions (fuel metering may be correct, but anticipated air flow is not). I don't suspect disconnection of your battery is responsible. Any long term fuel trim values in the PCM are coarse adjustments. The short term fuel trim (fine adjustsments) are accomplished through the PCM's reading of the O2 sensor's flucuating voltage signal. That is not a stored value but varies as soon as the engine goes into closed loop operation.
Old 07-24-2006, 11:43 PM
Braves299's Avatar
Braves299 Braves299 is offline
Senior Member
2002 Chevy TrailBlazer LT
Make sure your gas cap is screwed on tight.
Carl Lee Combs
July 8, 1944 - February 20, 2002
"Gone for now, never forgotten"
Old 07-24-2006, 11:53 PM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
Vince, I wouldn't sweat it. You reset it & it didn't come back. The 4.2L runs a bit rich by nature so it doesn't take much to throw it over the edge. Running in open loop from the battery disconnection probably mixed her up for a bit. IMO, GM added the MAF sensor to the 2006's to help prevent this.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 07-25-2006, 08:58 AM
Vince's Avatar
Senior Member
Thanks for all the replies.
The light didn't come back on during the drive in to work, so hopefully everything is all right.
Old 07-25-2006, 10:44 AM
Fast68Camaro Fast68Camaro is offline
2006 Chevy TrailBlazer LT
Maybe this bit of insight will help, though I hope it is not the problem. I had this same code on a 1996 Monte Carlo Z34. I replaced both O2 sensors (a real pain on a DOHC car) and the code came back. Took it to the stealership who said "no, no, no, it's the O2 sensors, your partshouse brand is just not good enough for your car's computer". So I let them replace the sensors, light came on while driving home.
So back to the stealership. "Well, we can hear the plug wires arching, so its the wires and plugs". So I negotiate a credit for the O2 sensors and labor and let them replace the wires and plugs (again, not a fun job on the DOHC engine). Light comes on again after a day or two of driving.
So, by this time I'm getting pretty fed up with this crap, and the stealership finally gets a GM regional guy to come in. Push comes to shove, it was the injectors and they had to replace them all. $1,200 for the injectors, but I shouldn't complain since I got new wire, plugs, and O2 sensors for free right? Just 3 or 4 times losing use of my car with no rental coverage.
Hope your code turns out to be a fluke.
Old 07-25-2006, 11:15 AM
Vince's Avatar
Senior Member
Hopefully it sis a fluke. I really don't want to have to go through the dealer "troubleshooting" the problem. The dealers seem to do more part swapping than troubleshooting. The good news is if the code does come back I have ~2000mi left on the warranty.
Old 07-25-2006, 11:46 AM
Envoy Fan's Avatar
Envoy Fan Envoy Fan is offline
TrailVoy Guru
2005 GMC Envoy Denali
Summit White 5.3L V8 4X4
You might want to consider an extended warranty while you still can get one.
BILL
Old 07-25-2006, 01:28 PM
Vince's Avatar
Senior Member
Yeah, i thought about it. I think they charge an absurd amount of money when you buy the warranty with that many miles on the vehicle. I might look in to it some more since I plan on keeping it at least 4 more years.
Old 07-25-2006, 02:05 PM
MTPockets's Avatar
4.2L I6 4X4
.... it was the injectors and they had to replace them all. $1,200 for the injectors, but I shouldn't complain since I got new wire, plugs, and O2 sensors for free right? Just 3 or 4 times losing use of my car with no rental coverage.
I can almost bet it wasnt the injectors themselves on that Z34 if you had a lean code. It was probably a vac leak around an injector (bad O-ring). A dirty MAF sensor would screw up the fuel trim on the GM DOHC V6's as well. That dealership got lucky as they threw enough new parts on her to make the SES light go away. Big thing to remember is to NOT replace an O2 sensor based on lean or rich code! The O2 sensor is telling you something is not right upstream.
Joel
Similar Threads
Build Sheet lucaswhunter General 29 05-27-2012 02:42 PM
03 tb has no power engine code P0172 joeyb123 Pictures and Videos 5 03-08-2012 12:11 AM
Code cleared itself. Now time for inspection. bugeyed OEM Issues 0 12-09-2007 09:22 PM
Cat is getting plugged AGAIN!! Bonez2 02-09 Vortec 4.2L I-6 Engine and Drivetrain 10 06-29-2007 04:40 PM
Code P0172 ?? rbarrios OEM Issues 6 08-04-2006 10:01 PM
