Fan Clutch Failure Symptoms? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain
02-09 Vortec 4.2L I-6 Engine and Drivetrain Q&A forum for engine and drivetrain repairs/modifications/tuning.
Old 07-26-2006, 10:01 AM
Rob Rob is offline
2003 Chevy TrailBlazer LTZ
What are the signs of fan clutch failure? Mine seems to be making more noise at startup and low speeds. Once engine speed is above 2500 rpm the fan must disengage because the sound fades away. Even when the engine is cold the fan engages at low speeds, but not all the time.
Quick reply to this message
Old 07-26-2006, 10:02 AM
blktbz's Avatar
blktbz blktbz is offline
TrailVoy Guru
2002 Chevy TrailBlazer LS
Onyx Black 4.2L I6 4X4
If youre truck sounds like an F-18 at any time, you have failure
Ex-TrailVoy'er, Current S10'er.
Old 07-26-2006, 10:20 AM
Raymond Raymond is offline
Two-tone 4.2L I6 2WD
Is your a/c on when it makes this noise? I don't know if that has anything to do with it or not I've noticed that mine has started making that noise at low speeds if the a/c is on.
Old 07-26-2006, 10:49 AM
Rob Rob is offline
I'm sure having the A/C on activates the fan at lower speeds and more often, but mine seems to be running when I don't think it should be. I have no problem replacing the clutch, I just want to be certain that's the problem.
Old 07-26-2006, 10:52 AM
trailblazingold's Avatar
trailblazingold trailblazingold is offline
2006 Chevy TrailBlazer LS
Singularity Silver 4.2L I6 2WD
Thats insane cause i have a 06 with almost 8000k and it sounds like a jet engine in the morning at low speeds.
Old 07-26-2006, 10:59 AM
Rob Rob is offline
Mine does the same thing. I just don't remember it being so bad last summer. Could be me though. If you're sitting, idling for extended periods of time or doing something else that causes the engine to run warm, the fan is certainly going to kick in and make a lot of noise. However I don't think it should be on when the engine is cold. Last night it was around 80 degrees and raining. My fan was making all kinds of noise even though I was cruising along at around 25mph. I don't think that's right. Rev the engine above 2500 rpm for a few seconds and the fan quiets down.
Old 07-26-2006, 11:04 AM
Jman423's Avatar
Jman423 Jman423 is offline
Red Jewel Tintcoat 6.0L LS2 V8 2WD
The only time my A/C actually works right (i.e. cools down quickly at startup) is when the truck does sound like an F-18. The problem I've been haviing is that the fan doesn't seem to engage when I startup, and the A/C takes forever to cool down. I've already had this addressed by the dealer and they replaced the fan clutch after the pressure switch didn't fix it. Funny enough, it worked great for the spring, but it is going back in tomorrow to get the same problem addressed again.
Old 07-26-2006, 12:07 PM
I thought I had read something that said they was a revised fan clutch, Jman when you had your fan clutch replaced the first time was it with a revised one?
Old 07-26-2006, 05:32 PM
jmlock's Avatar
jmlock jmlock is offline
Mine is the same way, but it goes away after a minute or so. I read in the manual or somewhere that it is normal on cold start up.
Old 07-26-2006, 09:13 PM
Dave's Avatar
Dave Dave is offline
2006 GMC Envoy Denali
Red Jewel Tintcoat 5.3L V8 4X4
It sounds like normal noise to me also. My 06 Denali does it everyday but it always blows cold air. My 03 TB (with new fan clutch) use to sound that way but it has been quieter lately, but it also doesn't blow cold air at idle. I'm taking the TB in on Monday.
2009 GMC Yukon XL Denali AWD (replaced 06 Envoy Denali)
2007 Chevy Impala SS, 5.3 (replaced Totaled 03 TB EXT)
2008 Chevy Corvette 4LT (my toy)
You may not post new threads
You may not post replies
Similar Threads
How to replace fan clutch? mattbuff5 OEM Issues 178 04-29-2016 12:46 AM
Fan clutch 101 GMT 360 OEM Issues 366 12-01-2015 10:26 AM
OEM Trailblazer, Envoy Electronic Visco Fan Clutches EuroPartsAmeric Basic Vendor GroupBuys 26 01-14-2012 02:54 AM
service bulletin# 060602003 bcslvrss OEM Issues 11 05-28-2009 07:17 PM
Fan Clutch or Water Pump?? Please help Thanks exvetteowner OEM Issues 9 02-09-2008 11:29 AM
