Oil in spark plug hole - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain
02-09 Vortec 4.2L I-6 Engine and Drivetrain Q&A forum for engine and drivetrain repairs/modifications/tuning.
Old 09-13-2006, 04:48 PM
Badvada's Avatar
Badvada Badvada is offline
2002 Olds Bravada
Black 4.2L I6 AWD
When I was changing the plugs and got to the second hole from the front I found about 3 or 4 drops of motor oil at the base of the hole. All the others were dry. All I can think of is a gasket is leaking. Maybe valve cover gasket? Is this common? BTW it has 91k miles on it. Thanks.
Quick reply to this message
Old 09-13-2006, 04:55 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Seems like it is a common thing.. mine had a little oil in a couple, and have read a few others finding the same.
Old 09-13-2006, 06:08 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
Very common on this type of cylinder head. It's rare to see a completely dry spark plug well once they get up in miles on any make/model. Most tower seals are just an O-ring, but given the egg shaped chambers on the vortec 4.2L, they are probably an RTV seal. 2006+ appear to have a cylindrical (o-ring) design.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 09-14-2006, 09:07 PM
bullethole's Avatar
bullethole bullethole is offline
Senior Member
2002 Chevy TrailBlazer LT
Sandstone Metallic 4.2L I6 4X4
Just changed mine and noticed a small amount on #3. Put the new one in and did not worry about it. My Honda 2.2 has similar design and it did the same thing starting at 100k.
Old 09-14-2006, 09:31 PM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
Hmm, bet that's why then went to an aluminum cover for '06, to keep the leaks to a minimum. The newer aluminum cover should provide more even force across the entire length of the cover, as opposed to the original composite piece.
You may not post new threads
You may not post replies
Similar Threads
Joke of the Day Blulytes Everything Off-Topic 1947 06-08-2016 08:26 PM
New Spark Plug Information for the 4.2L I6 Crossroader General 38 06-18-2013 03:18 PM
oil in spark plug valley neilLTZ OEM Issues 5 07-27-2010 09:45 AM
WI Dealer giving me the BS on OCI? Knightslugger General 48 10-10-2009 11:12 AM
oil change DzSoLow Everything Off-Topic 4 03-15-2007 01:00 AM
