Lug Nuts? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Rims
Rims Rims/Wheels
Old 08-17-2005, 10:57 PM
jbachert jbachert is offline
2005 GMC Envoy Denali
Black 5.3L V8 4X4
Lug Nuts?
When installing aftermarket wheels do the factory lug nuts work?
I only ask this because on my other car (Audi - which uses lug bolts - not nuts) - I needed different lug bolts - taper seat instead of the ball seat bolts that came factory.
Also, how about hubcentric rings? Are you guys using them with your after market wheels?
Thanks,
John
Old 08-17-2005, 11:43 PM
Cmdrrjc's Avatar
Cmdrrjc Cmdrrjc is offline
Senior Member
2002 GMC Envoy SLE
Fire Red 4.2L I6 2WD
My answer may be simple but for the most part when you get aftermarket rims/wheel. They add in the lugnuts. So basically you will not really need to use those factory lugs...I hope this kind of helps. Maybe someone else can add to my answer.
Raf /
2004 GMC Envoy SLE
"Wouldn't it be nice if whenever we messed up our life we could simply press 'Ctrl Alt Delete' and start all over?"
Old 08-18-2005, 01:30 AM
tb_ky's Avatar
tb_ky tb_ky is offline
2002 GMC Envoy SLT
Black 4.2L I6 4X4
Im not sure but I know that my factory "lug nut remover" wont work with my rims.
2006 Cobalt SS Supercharged Sunburst Orange
Gm Stage 2, Injen CAI
RIP: 2003 Trailblazer LT Black w/ 20" Helos (Black Betty)
Old 08-18-2005, 08:51 AM
Blulytes's Avatar
Blulytes Blulytes is offline
2008 Audi A6 3.2 Quattro S-Line
Silver Other AWD
It all depends upon the rim.
I know that some OEM lugs have a fatter head which do not fit into the holes for some wheels. Also as some of us have found, our "tire iron" or "lug nut remover" as some of us call it does not fit the smaller lug nut hole.
I used to have to carry a Snap-on Socket Wrench and a pipe (for leverage) on my old truck for this reason.
Also the factory ones are ugly. Most aftermarket ones, which will be exposed, are usually chromed, getting you an extra 10 bling points.
Ask the dealer, as they most likely will have mounted rims from that manufacturer onto someone's vehicle and they should know.
Me-Joe
Old 08-18-2005, 02:07 PM
Black 5.3L V8 4X4
Well, I bought the wheels of of Ebay, so I can't really just ask the dealer that is installing them - I am kind of on my own.
Also, I don't need chrome lug nuts because there is a center cap that covers the nuts - so if the factory ones fit that is fine.
Guess I'll have to wait to see when they arrive.
Old 08-18-2005, 04:07 PM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
If you bought chrome rims, DO NOT use the factory lug nuts.....you'll hate yourself after seen the chrome scraped and/or chipped where they contact the mating surface of the rims. If you have wheels with hidden lugs it may not be a big deal, but for the majority of the wheels out there you'll see the damage. Do yourself a favor and go down to the local three stooges or your favorite parts store and buy a set of chrome lugs. (I think the size is 12mmx1.5 - but double-check the applications book before buying).
Also with chrome lugs/rims, using a non-chrome plated socket to remove them, ala the factory tire wrench, will cause damage to the chrome plating. You should ONLY use chrome vanadium sockets when installing or uninstalling chrome wheels & lugs to prevent possible damage. - And make sure the local wrench monkey takes the same precautions if they need to remove a wheel for any reason.
Similar Threads
Please help me with lug nuts... jmlea0 Rims 3 06-22-2008 09:43 PM
Question about lug nuts shelly04 Rims 11 05-27-2008 06:46 PM
Decent Lug Nuts... aak274 Rims 5 03-04-2008 08:35 AM
Lug nuts needed for SS rims? Conical? aak274 Rims 1 12-13-2007 08:49 PM
Lug nuts needed for SS rims aak274 Rims 4 12-13-2007 01:29 PM
