Hum noise when turning steering wheel - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-18-2005, 11:37 PM
The Black Pearl's Avatar
The Black Pearl The Black Pearl is offline
2004 Chevy TrailBlazer LS EXT
Black 4.2L I6 4X4
I am wondering if anyone is getting a hum noise from the front of the TB when turning the steering wheel while the TB is not moving. I get this noise once and a while I can not duplicate the noise when I want to.
Thanks
FORE...
If the straw hat fits.
You Hillbilly
Old 08-19-2005, 12:18 AM
homertime's Avatar
homertime homertime is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
It's usually not good to just turn the wheel when the car isn't in motion... rips apart the tires
Old 08-20-2005, 01:01 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
I noticed last year, while I was straightening out in a parking space, mine makes a slight "rrrrr'" "rrrrrr" sound moving the wheel left and right. There was a TSB concerning a rubbing feel or noise from the steering column. I did that, but that was not the problem. What I hear is from the rack or the pump. I can duplicate it in the garage by moving the wheel slightly l and r, not even enough to scrub the tires, just enough to load the steering system. Only does it though when it's hot. Does not do it at all cold. I added a bottle of LubeGard power steering fluid protectant about a year ago, and that reduced the noise to the point I do not notice it now.
Old 08-20-2005, 04:45 PM
Manbir Sandhu Manbir Sandhu is offline
you shouldnt even be turning your wheels if the car is not moving, just like how homertime said. your tires will wear out soon
Old 08-20-2005, 05:21 PM
tblazed's Avatar
Whether moving or not wasn't the point - I always try to be rolling at least a little bit when I steer the wheels. I'm more concerned about stress and wear to the steering links and other front end parts; not too worried about wearing out tires doing that.
My point was, my TB will make the steering noise after it gets hot, even at speed going down the road. It's just hard to hear or feel it when the vehicle's moving. Moving forward and backward in a normal manner straightening out in a parking space with the radio and everything else turned off is when I first noticed the sound it makes.
There is a TSB that addresses one cause for this - #02-02-35-006A - (02/27/2003) Squeak, Rub/Scrub Type Noise in Steering Column (Lubricate Upper Intermediate Shaft Serration (Slip) Joint and Remove Material from Upper Intermediate Shaft Bushing).
The sound I was hearing was not corrected with that TSB. It was reduced with the LubeGard.
Old 08-20-2005, 06:14 PM
tb_ky's Avatar
tb_ky tb_ky is offline
2002 GMC Envoy SLT
Black 4.2L I6 4X4
Sometimes you do not have a choice...Well wait...yes you do you can run into the car that is beside the parking spot you are trying to get out of
2006 Cobalt SS Supercharged Sunburst Orange
Gm Stage 2, Injen CAI
RIP: 2003 Trailblazer LT Black w/ 20" Helos (Black Betty)
Old 08-22-2005, 10:10 AM
04TBEXT 04TBEXT is offline
There is also a service bulletin for certain '04 year model vehicles for noise...I believe hum, buzz, vibration, moan @ idle when turning the wheel. It involves power steering rack replacement with an updated steering rack assembly...
Similar Threads
Problems with the steering wheel control BUC NASTY OEM Issues 11 04-13-2008 12:44 PM
creaking noise when I turn steering wheel hard right luvchampagne OEM Issues 12 04-13-2008 01:08 AM
Steering Wheel Control Not Functioning Sims Envy Audio and Electronics 5 03-10-2007 11:10 PM
High Pitch Noise When I turn Steering Wheel Ronbo General 3 08-01-2006 03:18 PM
knocking noise when turning the steering wheel? titan9 OEM Issues 4 08-07-2005 09:47 AM
