p0442 error code - help - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-02-2006, 02:40 PM
funkdoobiest's Avatar
funkdoobiest funkdoobiest is offline
2003 GMC Envoy SLT
This is my first post, hope I am putting it in the right spot. I have an '03 Envoy 6 cylinder with 39k miles. Recently received the service engine soon light and the reader showed error code P0442 which I have found to be and EVAP emissions control leak small. I need help diagnosing the exact cause of the problem.
Thanks.
Old 10-02-2006, 02:57 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
Most common cause is a loose or faulty gas cap. Sometimes the check valve in the gas cap doesn't seat properly allowing the gas tank pressure to bleed down. The EVAP system needs to see a positive pressure in the tank.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 10-02-2006, 02:58 PM
hingarfi hingarfi is offline
2002 Chevy TrailBlazer LT EXT
Carbon Metallic 4.2L I6 2WD
Maybe Gas Cap
Here is a quote from autotap.com
"One of the most common codes that results from a loose gas cap is P0440."
Might check the gas cap.
Hingarfi
Old 10-02-2006, 03:20 PM
2003 GMC Envoy SLT
Should have mentioned this earlier, but I checked the gas cap already and that's not the problem.
Old 10-02-2006, 03:29 PM
MTPockets's Avatar
4.2L I6 4X4
If you are positive the cap is good and only the "small leak detected" code persists, you'll have to sniff around for fumes (the leak). The 'charcoal box' and associated tubing is under the truck above the spare tire. The purge solenoid is under the intake manifold and the vac line routes to the throttle body. Those are listed on the under-hood EVAP schematic sticker. You could also have a leak on/around the tank or filler as well.
Joel
Old 12-13-2009, 02:51 PM
treekiller96 treekiller96 is offline
2004 Chevy TrailBlazer LS
finally!
this is the best description i have found in 2 days dealing with location of vac lines and other stuff dealing with p0442!
Old 12-13-2009, 03:14 PM
the roadie's Avatar
Well, then you're going to love this exploded view drawing. #4 is the purge solenoid, #7 is the vent, and #14 is the canister (on the first drawing for the short wheelbase vehicles, and the second drawing for the EXT/XL they're slightly different)
Click image for larger version
ID:	8549   Click image for larger version
Old 12-16-2009, 07:47 PM
DaveM1 DaveM1 is offline
2003 Chevy TrailBlazer LT EXT
Pewter Metallic 4.2L I6 2WD
I had this same code on my wifes 03 EXT. Bought the evap vent solenoid valve (part #7 in the second drawing) for 40 bucks at the dealer. Climb under the truck next to the gas tank and swap out took 5 minutes. Disconnect the negative terminal to clear the code and then drove home an hour tonight and still no code so this i think fixed it. Thanks to this site it saved me a bunch of money from my dealer. Funny thing is i just changed the same part on my 07 Tahoe last week.
Old 03-07-2010, 11:16 PM
78Southwind 78Southwind is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
bump!
Old 03-15-2010, 10:58 AM
jswineaiv jswineaiv is offline
2004 Chevy Trailblazer
evap leak
Is it really a big deal? I mean does does it mess with your gas mileage at all or what? I still have the code but I do not want to pay dealership to find the leak and charge me an arm and leg. I already changed the Gas cap with a GM part and still have the problem show up after resetting the system.
Similar Threads
Diagnostic Code P0442 awreed66 General 16 04-14-2015 06:55 PM
Gas Cap / P0455 code n0kfb General 38 09-04-2013 11:24 AM
P0442 code on low gas level bsl2ck OEM Issues 7 09-12-2008 02:47 PM
Engine code P0442 flip_mode OEM Issues 10 08-03-2007 11:51 PM
