Brake Pedal Switch Removal...... HELP!! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 10-05-2006, 08:34 PM
RangerHooptie RangerHooptie is offline
New Member
Angry Brake Pedal Switch Removal...... HELP!!
Does anyone know how to remove the metal clip that keeps the brake light switch in place? I am almost ready to get out the plasma cutter..........
Help please?
Old 10-06-2006, 09:17 PM
trailhill trailhill is offline
2002 Chevy TrailBlazer LT
Onyx Black 4.2L I6 2WD
i feel your pain, wish i was there its kind of hard to explain. when looking at the clip, get it to where you can see the pin its attached to. take a small screwdriver and pry between the top of the pin and the clip, it sort of hooks over the pin head, at the same time you have to push it up then it will pop off. once its off it will make sense, good luck.
Old 10-07-2006, 12:52 PM
New Member
Thumbs up Problem Solved
I got it thanks...... one thing to consider if you need to change the switch spend the extra .80 and get a new clip, then just snip off the old one.
Old 04-20-2015, 06:01 PM
Trailblazing15 Trailblazing15 is offline
Angry still no brake lights!!
so I have NO brake lights. all 3 are out. I have checked ALL bulbs and fuses. I have replaced the brake light switch.. what now? what do I check next??
Old 04-20-2015, 07:20 PM
EnvoyBoy2004's Avatar
EnvoyBoy2004 EnvoyBoy2004 is offline
2004 GMC Envoy SLT
Graphite Metallic 4.2L I6 4X4
Check fuse #12 in the underhood fuse box.
Old 07-24-2015, 01:44 AM
Noa Noa is offline
Lurking Newbie
2004 Chevy TrailBlazer LS
Black Granite Metallic 4.2L I6 2WD
Trailblazer DTC C0161
I will try the stop light switch to fix the code C0161, plus ABS and Brake line on and off, AC only works on 5 and chime on and off.
Noal
Similar Threads
how long have your brake pads lasted? shortyR6 Brakes 177 02-26-2012 12:33 PM
Rear Pads and Rotors ma2169 Brakes 4 02-29-2008 10:28 PM
Soft spongy brake pedal DonWs05 OEM Issues 7 01-28-2008 03:22 AM
Brake pedal stuck!! squiggyacfd Brakes 1 10-17-2007 12:23 PM
Brake Pedal Noise bbbwood OEM Issues 6 01-08-2007 05:55 PM
