oil filter and drain plug location - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-24-2006, 12:11 PM
TRAILBLAZRBURKE's Avatar
TRAILBLAZRBURKE TRAILBLAZRBURKE is offline
2006 Chevy TrailBlazer LS
Sand Beige Metallic 4.2L I6 2WD
Cool oil filter and drain plug location
hey there, just got my new 06 tb'r. also just set up this account and don't plan on being a newbie for long....so....just wandering where is the oil filter and drain plug on these I6'S. I see what looks like an access cover underneath the engine in the middle, but don't want to start messing with things until i'm for sure. please advise. THANKS.
Old 10-24-2006, 01:07 PM
RozmerJJ's Avatar
RozmerJJ RozmerJJ is offline
Senior Member
2005 Chevy TrailBlazer LS
Originally Posted by TRAILBLAZRBURKE View Post
I see what looks like an access cover underneath the engine in the middle.
That's the place. Once you open that you will see the plug and you will need to reach up into the opening and the filter will be on the passengers side of the engine. The first time you change it you may have a tough time getting the factory filter off as they really tighten them to tight.
Welcome and hope you enjoy the new ride!
Old 10-24-2006, 01:52 PM
thanks, i will check it out. will there be enough room to get a filter wrench in there to loosen the factory welded on filter. the way i usually do it is with a ratchet, breaker bar, and a socket style wrench. thanks again
Old 10-24-2006, 02:58 PM
Blueblazed's Avatar
Blueblazed Blueblazed is offline
2005 Chevy TrailBlazer LS EXT
Superior Blue Metallic 4.2L I6 2WD
You can use an old style filter wrench but it's tight. The socket style wrench with a couple long extensions works the best for me. It is easier to have the vehicle on ramps - I've done it both ways.
Old 10-24-2006, 03:47 PM
RozmerJJ's Avatar
Senior Member
When I did mine the first time I used a socket style wrench with a socket handel that had a pivot on the head so I could angle it down and long handle to get a good turn with. I have never had mine on ramps to do this but I can see where it would make it easier but not necessary.
Old 10-24-2006, 06:08 PM
Blueblazed's Avatar
Definately not neccesary to be on ramps, but for us old geezers it's sure a lot easier.
Old 10-24-2006, 08:19 PM
xpresseezy's Avatar
xpresseezy xpresseezy is offline
2003 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
i HATE where that filter is. the first time i changed my oil...oil everywhere...now im not that bad, jus takes some gettin used to.
Old 10-24-2006, 10:23 PM
Blueblazed's Avatar
especially about the oil everywhere part, though I've seen oil filters in worse places than the TB. Yeah, each change does get easier. One member said a while back that he takes his drill and drills a small hole in the bottom of the filter and lets it drain for a while before removing it. I just turn the filter a couple of turns with the socket wrench and give it a few minutes to drain in the pan.
Old 10-25-2006, 01:48 PM
Sounds like it will be messy then. But I just don't trust anyone else to touch my vehicles. So i will have to floor cleaner ready. Thanks again guys
Old 10-25-2006, 02:56 PM
BigJohnAZ's Avatar
BigJohnAZ BigJohnAZ is offline
Indigo Blue Metallic 4.2L I6 2WD
It is messy, I've tried placing a large ziplock bag around the entire filter to catch the oil as I spun the filter off, but I still made a mess. I like the sound of drilling a hole in the bottom of the filter to drain it before removing it.
BigJohnAZ
2003 LS Indigo Blue Metallic
Similar Threads
Joke of the Day Blulytes Everything Off-Topic 1947 06-08-2016 09:26 PM
Transmission filter and pan drop gomes512 General 43 03-12-2014 11:36 PM
Where's the oil filter? Vipers98Envoy General 21 06-16-2008 10:46 PM
Oil Drain Plug Lapdog57 General 3 05-04-2008 10:32 PM
oil change DzSoLow Everything Off-Topic 4 03-15-2007 02:00 AM
