oil filter and drain plug location - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-25-2006, 02:23 PM
95_ESi_Person's Avatar
95_ESi_Person 95_ESi_Person is offline
2002 Chevy TrailBlazer LTZ
2 Tone Majestic Red/Silvr 4.2L I6 4X4
it's a pain, but I've been getting the K&N oil filters for one reason... the 1" hex head on them, it's really easy with those, no slipping filter wrenches!
Next time I change my oil, I'm just going to remove the skid plate to make it a little easier with less scratches on my arm.
Old 10-25-2006, 02:27 PM
Crossroader Crossroader is offline
I changed my oil for the first time a couple of weeks ago.
I don't know why people make it sound so horrible to replace the oil filter and getting oil everyplace. I found it one of the easiest filters to replace and changing the oil wasn't messy for me. (Not unlike my Nissan P/U which was a PITA to change and messy too.)
I removed the entire access panel, not just the small access panel for the drain plug, and used a socket type oil filter wrench with an extension to slowly loosen the filter until I could see it drip. I let it slowly drip for a few minutes and then took it off with the wrench. I then put the new filter on. Then I drained the oil pan. The only area which had spilled oil on it was the built-in oil drainer underneath the oil filter; and it was minimal. Hardly even got my hands dirty.
I probably had more of a problem putting the filter on hand tight because my hands were too big to come in through the access panel. Using tblazed's trick, I had my wheels turned to the right and came in through the right front wheel well/front fender and was able to install and tighten the oil filter.
Piece of cake.
  #13
Old 10-25-2006, 03:46 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
Amen to that. I've had a cpl of nissans. Talk about a royal PITA of an oil change! The 4.2L trailvoys are gravy train compared to those.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
  #14
Old 10-25-2006, 05:27 PM
Impalacat Impalacat is offline
Oil filter and drain plug location
The 1st time, I changed mine I had a little mess, I always punch a hole in the bottom with a hammer and center punch to let them drain,the last time, I used the gallon freezer bag like, BigJohn AZ said, and had no mess what so ever, and I also take the big plate off, gives you more working room and it,s only 4 bolts.
62 Impala S.S.- 66 Impala 396
00 Chevy Ext Cab Stepside LT 2 WD
06 Trailblazer LS 4X4
  #15
Old 10-25-2006, 08:09 PM
xpresseezy's Avatar
xpresseezy xpresseezy is offline
2003 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Joel
i went to my tb from a neon, and an explorer...compared to those, my tb is a ....
  #16
Old 10-26-2006, 08:43 AM
RozmerJJ's Avatar
RozmerJJ RozmerJJ is offline
Senior Member
Originally Posted by Blueblazed View Post
Definately not neccesary to be on ramps, but for us old geezers it's sure a lot easier.
I'm no spring chicken but I can still slide under the truck.
If I was doing more than just the oil under there I would use the ramps.
  #17
Old 12-17-2008, 03:59 PM
Saxman's Avatar
Saxman Saxman is offline
2006 Chevy TrailBlazer LT EXT
Summit White 4.2L I6 4X4
I just did it (and this is my FIRST post here, too). It looks deceptive under there since the rear of the oilpan is visible, but there is no drain plug back there.
Definitely take off the skid plate by removing the 4 outer bolts with a 13mm socket. (No need to undo the smaller access panel's two bolts)
Once the oil is drained from the engine (13mm socket), I put the bolt back in and moved the pan under the filter. I loosened the filter until oil started to come out and let it drain while I changed out the air filter and filled the washer fluid.
If the skid plate is removed, none of the oil that dripped from the filter will hit the car - only the oil pan. The filter can be maneuvered down without spilling any of it - and voila! All the messy work is done.
Thanks for the info in this post. It really helped!
Andrew
  #18
Old 12-17-2008, 10:54 PM
rrufast's Avatar
rrufast rrufast is offline
2002 Chevy TrailBlazer LS
Wonder if they changed the drain plug from my 02 to yours? Just changed my oil yesterday and the oil pan drain plug is a 15mm. I don't remove the skid plate.. I just drop the access door and go to it...
PS-
Noticed my oil consumption appeared to have been nearly 3.5 qts in 10k miles... Only had about 3.5 come out of the pan.. Damnit... No smoking, no dripping.. no sign of leaking anywhere... nothing under the truck (as blowby)... I think it may be time for a ring job... which means this will become someone elses headache.. more than likely...
Gonna keep an eye on it for now and see what happens...
Southeast Chapter SC Rep The Happiness of Society is the END of Government!
  #19
Old 12-18-2008, 12:06 AM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
PS-
Why? 3.5 quarts in 10K isn't that bad. That's about a quart every 3K miles give or take. GM would tell you 1 quart in 1,000 is okay. (Didn't say I'd agree with them).
  #20
Old 12-18-2008, 12:54 AM
2003 GMC Envoy SLT
And being 3.5 qts. low....Maybe checking more often is in order. There was at least one TV'er on here who lost a motor to no oil. And IIRC he never got a low oil light.
Similar Threads
Joke of the Day Blulytes Everything Off-Topic 1947 06-08-2016 08:26 PM
Transmission filter and pan drop gomes512 General 43 03-12-2014 10:36 PM
Where's the oil filter? Vipers98Envoy General 21 06-16-2008 09:46 PM
Oil Drain Plug Lapdog57 General 3 05-04-2008 09:32 PM
oil change DzSoLow Everything Off-Topic 4 03-15-2007 01:00 AM
