Windshield wipers wont turn off. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-25-2006, 08:15 PM
dallas16v dallas16v is offline
I am confused unless its the switch or the relay. I am thinking the relay since the 2 fastest speeds will change the speeds of the wipers. Anyone else experience this issue?? BTW: HI I am a noob..
Old 10-26-2006, 01:27 PM
TRAILBLAZRBURKE's Avatar
TRAILBLAZRBURKE TRAILBLAZRBURKE is offline
2006 Chevy TrailBlazer LS
Sand Beige Metallic 4.2L I6 2WD
Sounds like a relay. Unfortunatly GM wiper motors, pulse modules are notorious for failing. Sounds like a relay, but may not hurt to have the pulse module checked out. alot of time, moistuture gets in them and everything starts acting goofy.
Old 10-26-2006, 02:25 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
All the electronics and relays are contained in the wiper motor ass'y. The steering column control stalk connects to the wiper motor unit through the vehicle wiring harness. Pretty simple but does get water in it sometimes, and even though there was a NHTSA safety recall about this, the "fixed" ones still fail. Water will get inside, corrode and make conductive leakage between circuit traces on the control board, and cause weird problems.
Old 10-28-2006, 01:50 PM
PaulSVX's Avatar
PaulSVX PaulSVX is offline
2002 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
There is a recall for this problem. Mine was doing the same thing
Old 04-29-2014, 07:22 PM
tmarti50 tmarti50 is offline
2005 Chevy TrailBlazer LS
Sandstone Metallic 4.2L I6 2WD
I called GM's recall department but they had no recall for my 2005 TB. maybe it was just for the 2003-03. I have pulled the #9 fuse under the hood and wipers are still going nonstop!! How can I get them to stop just till i can get this fixed???? it's not raining in tx!
Old 07-03-2014, 02:20 PM
juggalo_g's Avatar
juggalo_g juggalo_g is offline
trailblazer lt Chevy TrailBlazer LT
Graphite Metallic 4.2L I6 4X4
re;
the fuse is under the back seat
Similar Threads
Wipers do not turn off. jpshields25 TrailBlazer / Envoy Chat 8 12-09-2010 03:33 PM
NEW problem with windshield wipers mechas76 OEM Issues 3 01-16-2008 07:31 PM
Auto headlights & windshield wipers Frostee General 3 10-09-2007 11:09 AM
Front Wipers skipping across windshield 77corv General 5 09-11-2007 10:50 AM
help wipers won't turn off gizmoe399 General 6 02-13-2006 09:19 PM
