Clarification on Fuel Filter Change - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-30-2006, 07:27 PM
steviestyles's Avatar
steviestyles steviestyles is offline
2005 Chevy TrailBlazer LT
4.2L I6 4X4
I've searched over the forums, and noticed that this topic has been covered to some extent; however, most of the topic has been how to change pre 2005 models. I guess supposedly the Fuel Filter on the 05-up has been put in the tank, so it's non serviceable. If so, how come it still claims to service the Fuel Filter every 25k mi in the 2005 TB Owners Manual. I searched Parts America for a fuel filter on an 05 as well as 06 and they actually have a filter listed. So what gives? I really don't want to go to the stealership and get ripped when I don't need this service done, let alone come off as a non car knowing guy they can take to the cleaners.
Old 10-30-2006, 07:47 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
2005+ 4.2's have pretty much a completely different fuel system than 2002-2004's. 2005+ use a variable speed fuel pump with no return line and no fuel pressure regulator. I belive they call it a 'pulse width modulated' fuel pump where the PCM regulates the voltage to the pump based on engine load. With different plumbing and hardware, I'd have to say the filter is different as well and probably in the tank somewhere. I *assumed* it was a sock on the pump p/up, but I have yet to verify this.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 10-30-2006, 08:22 PM
4.2L I6 4X4
Went to NAPA this afternoon, and asked for the Fuel Filter for my TB. According to the guy at NAPA, it's still the canister style type. I decided to hold off until I made sure that mine was not in the tank.
Old 11-01-2006, 10:55 AM
MTPockets's Avatar
4.2L I6 4X4
If the supposed 2005 filter napa has looks like a 2002-2004 fuel filter, it aint right. There is no inline filter to be had on a 2005. I've looked on mine...
Joel
Old 11-02-2006, 11:31 AM
4.2L I6 4X4
Thanks for the input Joel,
I'm going to change my oil today. While I have it up on the lift, I'll check to make sure mine doesn't have the fuel filter located on the rail. I talked to my local chevy dealer; they told me some of the early model 2005's still have the external replaceable filter. My vehicle was built in late Feb 05, so I'll check.
Old 11-02-2006, 11:54 AM
mastermonkhabib mastermonkhabib is offline
2002 GMC Envoy SLT
Monterey Maroon Metallic 4.2L I6 2WD
Napa is the same one that sold me a PCV valve for my I6 Trailvoy
For those who don't know, Trailvoys don't have on for the I6 (not sure about the others)
Old 11-02-2006, 11:55 AM
TRAILBLAZRBURKE's Avatar
TRAILBLAZRBURKE TRAILBLAZRBURKE is offline
2006 Chevy TrailBlazer LS
Sand Beige Metallic 4.2L I6 2WD
http://198.208.187.182/internet/View...rtNumber=GF831
AC Delco # is GF831. Take a look at the link and see if you recognize it.
That listing came up for an 05. Probably is early production as you have said
Old 11-02-2006, 02:26 PM
RozmerJJ's Avatar
RozmerJJ RozmerJJ is offline
Senior Member
I just did a serch on the AC Delcom site for a 2005 TB and they do not list any fuel filter. But is I select 2004 then the can style filter shows up.
Old 11-02-2006, 02:49 PM
Bearcat's Avatar
Bearcat Bearcat is offline
2004 Chevy TrailBlazer LT
That one works on my 2004.
They stuck it in the fuel tank.
All's well that ends well!
Old 11-02-2006, 03:04 PM
Cool
I too am pretty sure its in the tank, but i used the gm parts lookup software here at my parts warehouse and it said "may" fit 05. I only posted the link to the pic to see if he recognized it. Chances are he won't because its not there.
Similar Threads
Fuel Filter Line Disconnected AndrewB General 4 02-10-2010 10:38 AM
Fuel Filter And Motor Oil DAPABEYS OEM Issues 5 05-27-2008 03:12 PM
anyone change their fuel filter yet? 02Lightning OEM Issues 14 09-05-2007 06:32 PM
Fuel Filter Jbird13329 02-09 Vortec 4.2L I-6 Engine and Drivetrain 10 03-07-2007 01:15 PM
Fuel Filter Replacement DixieTBlazer 02-09 Vortec 4.2L I-6 Engine and Drivetrain 29 11-20-2006 05:27 PM
